Supercharger does not whine?
Old Sep 26, 2011 | 05:47 PM
jag79's Avatar
Originally Posted by JagV8
How do you know it flows +200cfm more on the 3.0?
BTW, your truck experience is irrelevant as these cars are far better designed and have far better air flow.
I stick by my point that it won't markedly affect the STR's SC whine.
good ol JagV8! How are you mate? Regardless of all the positives the K&N has to offer you always been a staunch hater of K&N air filters , for a very long time, but its all good! I too once was hesitant to place one in my STR, but once I did with Mafiosos Air intake and the Baffle removal, it made a huge difference. Just my two cents
Peace!
Old Sep 26, 2011 | 05:55 PM
JagV8's Avatar
As I just wrote, if you change some/all of the rest of the intake you may want to change the filter. Etc.
I've seen far too many faults caused by K&N ever to use one on my own car.
Old Dec 24, 2011 | 06:35 AM
V8 Str's Avatar
To aid the whine, remove the black cover over the charger and coolers, remove the under hood sound deadening and it will definately be louder. Alongside this i have taken the air box baffle out and dropped a K&N in.
Whilst removing under hood insulation does not aid air intake to the filter box it does open up a small 3/4 inch gap to allow cold air into the engine bay from the main center vent allowing for lower under hood temperatures in the engine bay.
I am very pleased with the whine now really throaty, i am looking at a pulley change in the new year and fabricating a similar intake to the Mafisio one over here in the UK, then whether a open airbox/heatshield can also be fabricated with dedicated air intake and flushed bonnet vent...
Old Dec 24, 2011 | 08:07 AM
Bacardi 151's Avatar
What exactly is plugging the silencer ports? Are these ports on the blower itself or are we talking about the 4 "arms" that protrude from the intake tube? My blower is currently off the car due to the under the S/C coolant leak...
Old Dec 24, 2011 | 08:20 AM
bfsgross's Avatar
Regarding: plugging blower vents, I believe V8STR is referring to the blowers internal boost bypass channels. These relieve boost to both not overboost and cut down blower whine. Eaton rebuilders/modders offer to block the bypass vents to accelerate building boost. The end result is more boost at the expense of too much whine for most appetites...ok for a track dedicated car.
Old Dec 24, 2011 | 09:27 AM
I'm gifted with the endless desire for excess
Here's a thread... She's a screamer! Plugged SC Silencer Holes Eaton Supercharger - Saturn ION RedLine Forums
Left my mechanic a VM, hope he's up for the job and it's not too late...
Old Dec 24, 2011 | 09:43 AM
Michael Star's Avatar
Hmmm. So are those ports just for sound? Does it help to build boost quicker?
Old Dec 24, 2011 | 10:27 AM
  #28
According to the redline forums who claims they got this from Eaton:
"The two oval slots on the output plate are air leakage ports. Their only purpose is to decrease operational noise from the blower. Arnie, from Eaton Corp., explains their function like this, "When you stomp on the gas, the boost shoots up and the air flow goes supersonic. The air then slams back into the output plate and through the leakage slots, which reduces the hammering of the air into the housing causing less noise. The OEM can not have such loud NVH, that’s why we put them in the housing. The 2 small ports are not there to feed air, only to reduce noise." Basically, for the best flow and most efficiency, these ports can be blocked off, making the outlet port (triangle slot) the only port on the outlet plate of the housing. Closing these ports will not increase IAT's; however, it will make the supercharger much louder when in boost. As an example, aftermarket supercharger companies, such as Harrop, Roush and Magnuson do not use these slots in their blowers. It should be re-stated, that you should consult professionals regarding closing these ports; and do not, for any reason, plug them with JB Weld. Improper closure could eventually lead to pieces coming apart and loose debris destroying the rotors and housing. Opening up these ports will only have a negative effect on efficiency. Do not port them."
Old Dec 24, 2011 | 11:42 AM
clubairth1's Avatar
Community Influencer
A picture might help. Note the big triangle and the two smaller slots. I think these two slots are what they are talking about. This is a ported blower next to a stock one. It's hard to tell any difference and of course there are NO dyno test of any kind to back it up any claims.
Attached Thumbnails Supercharger does not whine?-steigmyer-ported-blower-next-stock-4.0.jpg
Old Dec 24, 2011 | 12:06 PM
  #30
Thanks for the visual aid...I guess the question is how (and more importantly how much) to plug the holes...If I could find someone and it needs to be done this tuesday or wednesday only, to weld and grind for like $100 I'm down, but otherwise I may try the epoxy route...
Porting is really an "one size fits all" blanket term...A lot of port tech are artists and just grind everything by eye...Maybe they'll be gains, and maybe it'll be affordable...But, to get the maximum results, it's a science...Need lots of trial and error with flow testing along dyno runs to ensure the computer isn't messing with fuel trims or timing in a negative way...
For a fun read, check this out: http://ls1tech.com/forums/advanced-e...r-intakes.html basically the premise that golf ball dimples have proven better flow on golf ***** and fuel economy on a car that had added dimples via mythbuster...Intake manifolds may someday have golf ball dimples along with the prius's exterior...lol
Old Dec 24, 2011 | 03:36 PM
  #31
bfsgross's Avatar
Dimples and ridges allow air/gases to slide rather than twirl or tumble...like that used on the surface of airplane wings. This principle is also used in cylinder head porting to prevent turbulence.
Old Dec 25, 2011 | 11:26 AM
  #32
This principle is also used in condoms (yes, seriously, lol) although i'm unsure if it's to prevent turbulence or not...
Old Dec 25, 2011 | 11:57 AM
  #33
Eaton Superchargers Modification Guide - Eaton Inside
Old Dec 26, 2011 | 08:04 AM
  #34
Good read, if you read between the lines, it further supports the use nitrous vs a pulley...
Old Dec 27, 2011 | 06:47 AM
  #35
Yikes! Don't try this at home kids
M112 Supercharger bench test - YouTube
Old Jan 19, 2018 | 05:40 AM
  #36
User 070620's Avatar
this site does not work !! I'm crying....
someone saved the document in pdf?
Old Jan 19, 2018 | 10:11 AM
  #37
Busa's Avatar
I would not be in a hurry to use that link.
My total security package just blocked that link site as being malicious when I tried the link to see if it was working.
Old Jan 20, 2018 | 02:05 AM
  #38
JagV8's Avatar
You don't want it. The Eaton is maxed out. If you want more power fit a different SC (as others have).
vwbusbits
Oct 13, 2015 03:43 AM
inactualis
Oct 2, 2015 11:13 AM
Johncy2000
Oct 2, 2015 01:05 AM
Col. Sandurz
Sep 28, 2015 07:29 PM
