TB intake Rubber Boot... Size??
Old Apr 12, 2012 | 12:11 PM
mystype04's Avatar
Default TB intake Rubber Boot... Size??
My car is an S Type "R"
Can Anyone tell me how big it is:
  • The TB inside or outside diameter?
  • The Intake Elbo that connects to the TB?
I have a major vacuum leak and its causing a missed fire in cylinders: 1, 3 and 7... I've checked the Compression, changed the spark plugs and even swap the Coils. I've also checked all the pins in every Coil Connector.
So far its not going away. My best guess is the intake Rubber Boot for the TB and Im planning to replaced it with a Silicon one.
Thanks,
JG
Old Apr 12, 2012 | 05:12 PM
bfsgross's Avatar
What model "S"?
Old Apr 12, 2012 | 07:30 PM
mystype04's Avatar
Sorry bfsgross. The car is a 2003 STR.
Old Apr 13, 2012 | 01:46 AM
JagV8's Avatar
It'll be interesting to find out as this looks to be a most unusual problem for an STR.
Old Apr 13, 2012 | 01:00 PM
blaksplash's Avatar
i'll be measuring mine tonight, i'll let you know.
Old Apr 13, 2012 | 09:28 PM
blaksplash's Avatar
here are the measurements of the TB to intake elbow rubber coupler:
  • the smaller TB side has an ID of 3.38"
  • the larger intake elbow side has an ID of 3.9"
calipers didn't fit too well back on the TB, but a rough check pretty well matches the ID of the rubber coupler, maybe a slightly smaller.
OD of intake elbow 3.93"
Attached Thumbnails TB intake Rubber Boot... Size??-2012-04-13-21.15.02.jpg   TB intake Rubber Boot... Size??-2012-04-13-21.15.12.jpg   TB intake Rubber Boot... Size??-2012-04-13-21.16.28.jpg   TB intake Rubber Boot... Size??-2012-04-13-21.17.23.jpg   TB intake Rubber Boot... Size??-2012-04-13-21.22.48.jpg
Old Apr 14, 2012 | 12:25 PM
jar's Avatar
jar
You'll be luck if it's at the boot.
At 115K, my boot looks pretty good (and it's been on and off a bunch), I did replace the clamps.
If chasing an air leak, and you fail to find success with the boot, I would suggest you check the pcv line fitting where it returns to the TB - under the TB motor. It's the other end of the hard plastic line that connects to your pcv valve (the pancake looking valve on the passenger side valve cover). That plastic will fatigue and crack over time.
Yep, it's a pain, and does require removal of the TB as far as I could tell, but I had the same gremlins and codes - multiple misfires, knock codes, running scary rough (if it stayed running), all after I had buttoned up after replacing the coolant line under the blower.
I know I didn't answer your question, but, perhaps gave you another place to chase.
Kind Regards,
Lawrence
XJ40 ( XJ81 )
May 9, 2023 06:31 AM
Poet
Oct 6, 2015 09:40 PM
Gerard Radimaker
Sep 13, 2015 10:33 AM
jagent
Sep 12, 2015 09:10 AM
