Timing chain tensioner replaced(need help)
Old Feb 13, 2011 | 10:43 AM
JagV8's Avatar
If it's the same engine as in the S-Type (as I understand it is), you could get the workshop manual - it has all the torques etc. Worst case about $6 from ebay. (It's never too late!)
Old Feb 13, 2011 | 10:47 AM
34Ford's Avatar
Ya know the most difficult part about this job was getting all of the wires and hoses etc out of the way just to get to the left valve cover.
Lets just say there were some bad words flying around the garage that day.
One small nut way back behind the motor just had to be facing the firewall.
Old Feb 13, 2011 | 12:55 PM
That looks scary!
Old Feb 13, 2011 | 03:28 PM
34Ford's Avatar
This is how it sounded a few days prior to parking it.
After opening it up you can see where the chain just started to eat into the engine block. Glad I parked it.
http://www.youtube.com/watch?v=rBxY0iJ_Tu0
Old Mar 22, 2011 | 01:03 PM
b4a5r0t's Avatar
i just replaced my heads and had to take the cams off for a valve job, is there a guide anywhere around on the install i think im doing everything right following the all data instructions but im not sure, i have the motor in tdc and the shafts aligned with the middle timing flats aligned together, im ready to tighten the bolts on the left side but would rather double check than have the timing off, all help would be greatly appreciated
Old Feb 17, 2012 | 08:33 PM
tinantonio66's Avatar
Default tinantonio66
Originally Posted by tbird6
I have attached several sets of instructions on changing the timing chain tensioners on the Jaguar V-8. With good pictures. See if that will help??
HAY I HAVE A 2000 LINCOLN LS V8 3.9 HOW I REMOVE THE SECONDRAY TIMING CHAIN TENSIORN PLEASE HELP A PICTURE WOULD BE NICE
Old Feb 18, 2012 | 06:25 AM
Welcome to the forum,
Maybe it would be worth doing a search?
Old Feb 18, 2012 | 09:32 PM
  #28
NBCat's Avatar
Originally Posted by b4a5r0t
... is there a guide anywhere around on the install i think im doing everything right following the all data instructions but im not sure, i have the motor in tdc and the shafts aligned with the middle timing flats aligned together, im ready to tighten the bolts on the left side but would rather double check than have the timing off, all help would be greatly appreciated
Hopefully you have all the necessary special tools at your disposal to correctly align the camshafts and hold the crankshaft at top dead centre. Do you have the JTIS manual? If not, you should consider getting a copy prior to going any further with the camshaft instalation and valve timing.
NBCat
Old Feb 20, 2012 | 12:37 PM
tcap1047's Avatar
I am presently in the assembly phase of timing chain and tensioner replacement. If you need help, send up a flag.
xjrjag
Nov 27, 2025 09:16 AM
Bcrary3
Sep 12, 2015 08:43 AM
David Mason
Sep 3, 2015 03:17 AM
Bcrary3
Aug 31, 2015 11:29 AM
souldoubt
Aug 25, 2015 08:15 PM
