Too Much Play In S-Type Steering Wheel
Old Jun 20, 2023 | 07:22 PM
blackjag777's Avatar
Default Too Much Play In S-Type Steering Wheel
My 2000 S-Type 3.0 has too much play in the steering wheel. I replaced the rack and pinion, the front upper and lower control arms, and switched 20" chrome rims (too heavy) with 17" stock rims, and wheel alignment, I can turn the steering wheel about 1.5 inches in either direction before it actually start turning the wheels. This is obviously unsafe. Does anyone know how I can repair this? Thanks
Old Jun 21, 2023 | 02:42 AM
bydand's Avatar
Find out where the loss of direct drive is between the steering wheel and the drive to the steering rack.
Could be the splines between the steering wheel and the steering column, or at the other end between the steering column and the steering rack.
If the heavy 20in wheels have been on for any length of time, inducing wear in the steering drive.
Old Jun 21, 2023 | 08:45 AM
Thanks for your quick response. Can I buy the splines separately or do I need to replace the entire steering column?
Old Jun 21, 2023 | 11:09 AM
bydand's Avatar
BlackJag,
Like I said, You have to confirm where, the slack is.
If it is the top, Then steering wheel and the column,
If the bottom, the the rack and the column, Having changed the rack, then just the Column.
But please confirm where the slack is.
Old Jun 23, 2023 | 12:06 AM
Thanks. I will look into it this weekend.
Roger S
Aug 10, 2019 03:20 PM
chardynigelon
Feb 7, 2013 05:20 AM
jmcGoBlue
Mar 15, 2011 05:00 AM
manderson10
Apr 15, 2009 09:48 PM
