Towing Points
Old Jan 23, 2018 | 05:28 PM
Rex's Avatar
Rex
Default Towing Points
The rubber plug in the rear towing point is being stubborn to remove. Should have done this often as regular maintenance but failed. Now stuck. Is it threaded or just rammed in? If threaded, turning threatens to break the plastic retainer attached?
Old Jan 23, 2018 | 06:04 PM
JBzXJ40's Avatar
Are you not able to use the front one?
Im trying to remember now..... I think it just pulls out, not threaded. Is there not a hole at the rear to spray and WD-40 or equivalent?
Old Jan 23, 2018 | 06:25 PM
Rex's Avatar
Rex
Front one does not have rubber plug, rear one I cannot remove. Do not need it now but should be ready for deployment.
Old Jan 24, 2018 | 12:52 PM
clubairth1's Avatar
Community Influencer
You sure it's not left hand thread?
Old Jan 24, 2018 | 01:47 PM
Old Jan 24, 2018 | 11:41 PM
Rex's Avatar
Rex
Brilliant! My manual only states "remove the plug", no mention of left hand thread.
Old Jan 26, 2018 | 05:02 PM
Rex's Avatar
Rex
Removed the plug. Must break the plastic retainer to turn. Had never been removed and was seized. Broke and drilled it out. Need a tap and die set or thread cleaner to finish. Bottom line is remove every couple of years and grease! Forward end is open and entire unit full of grit. Now need to buy new plugs.
Tally Ho
Feb 21, 2016 07:51 AM
x
Aug 12, 2009 08:00 PM
Feb 26, 2007 09:24 PM
aquill1
Jan 21, 2007 12:48 PM
