Tracing vacuum leak
Old Mar 3, 2012 | 01:53 PM
neffry61's Avatar
Default Tracing vacuum leak
I have a 2000 S-type 3.0 that has had miss fire issues along with loss of power and gas mileage. It has 104,000 miles. I have replaced the cop's, o2 sensors, upper & lower intake manifold gaskets. I am using Pulsar Pulstar plugs. I recently took the fuel injectors out and had them re-done. After fighting issues with the spark plug tube gaskets leaking oil into the spark plug wells and shorting the coils I think I have that licked. The missing is gone for the most part but I'm getting a P0430 code and I want to rule out a vacuum leak before I start looking into more expensive problems. I've tried the cigar trick to try to locate a leak but I could not find anything. Any suggestions?
Old Mar 4, 2012 | 08:49 AM
JagV8's Avatar
Have you replaced both of the hoses which tend to perish and leak at their elbow?
You can check (long term) fuel trims using OBD live data. If there's a leak they'll change markedly between idle & 2500rpm. Much cheaper than swapping parts and hoping.
Lots of threads about this...
Old Mar 4, 2012 | 09:00 AM
aholbro1's Avatar
This is a common leak point on your model:
https://www.jaguarforums.com/forum/s...um-leak-67197/
Sorry, couldn't find a link to a the thread with a picture, but I know there is one on here, somewhere. This one has the p/n though.
Old Mar 4, 2012 | 11:45 AM
joycesjag's Avatar
Here is the thread that aholbro mentioned:
JagRepair.com - Jaguar Repair Information Resource
clubairth1
30
Sep 3, 2025 04:38 PM
aholbro1
Dec 29, 2024 06:46 PM
Bcrary3
Feb 21, 2023 04:29 AM
JWheeler
Nov 22, 2019 08:28 AM
OkieTim
Sep 8, 2015 04:48 PM
