track light flashing after new tyres
Old Dec 11, 2008 | 05:22 PM
bigdaddywuff's Avatar
Default track light flashing after new tyres
I have 2001 s-type 4.0 just put winters on. did not realize the set had two different sizes the fronts have pirelli P245/45/R17 the back has P245/50/R17. The car has always had 245/45/17 with no issues. Now the car speedo is different then my in dash speedo/navigation system about 6-7 kms different then the dash, but also the traction light keep flashing when i drive off and on. Also the shop also said the Two tires in the back were chopped/choppy. What would be the cause of all this jibberish? also the car runs nice and smooth no vabration just a humming coming frome rear wheels i believe the choppyness. All tires have 80-90% tread
Thanks in advance
Old Dec 11, 2008 | 07:39 PM
shift_grind's Avatar
Default RE: track light flashing after new tyres
sounds like you awnsered your own question. replace the rear tires with new ones that are the right size. your front tires are spinning faster then your rears causing issues and as you said the rear tires have flat spots.
Old Dec 14, 2008 | 01:49 AM
jaakennuste's Avatar
You have front/rear tire diameter difference 3,6% Thats too much!. Try to keep it under 3%, better even less. Traction control measures speed diferences between all 4 tires...
Jack
RonnieJoe
Dec 24, 2020 03:51 PM
redrover41
23
Sep 25, 2015 01:33 PM
mrplow58
Sep 9, 2015 11:27 AM
Bigvettefreak
Sep 6, 2015 04:27 PM
Mosers63
Sep 6, 2015 02:53 PM
