Transmission Fluid
Old May 19, 2008 | 08:19 PM
cosworth's Avatar
Default RE: Transmission Fluid
You have to drop the pan or use a suction device. As accomplished as I am at pulling wrenches, this is a specialist job. Tranny shop or Ford/Jag dealer to service the tranny. Mercon fluid btw.
Old May 19, 2008 | 08:41 PM
ibjags's Avatar
Automatic Transmission Oil
(specification WSS-M2C 202B) - JLM 21044
Old May 27, 2008 | 02:35 PM
Freddy2121's Avatar
Really hard to check the trans fluid. You have to drop the pan to change the fluid and you will need mercron fluid. The real challenge is getting the fluid back in the tranny. There is no dipstick or any place except on the actual side of the tranny to get the fluid back in. We made a homemade plastic pump and a rubber line to get the fluid back in. It wasn't a hard job, just tedious
Old May 27, 2008 | 07:19 PM
ibjags's Avatar
freddy
did you check fluid level with trans temp between 30 and 50 celsius
Old May 28, 2008 | 07:12 PM
jag_genius's Avatar
dont really need to rempve pan.. just drain and refill.. . measure what you take out and put in the same amount.. at the same temp a.. that will give you close enought then do the fluid check at 38 celsius
Old May 31, 2008 | 11:29 AM
ohsigmachi's Avatar
Ford Spec WSS-M2C 202B = Mercon V... NOTthe oldMercon spec
aholbro1
Dec 29, 2024 06:46 PM
Jandreu
Jun 30, 2022 03:10 PM
picard
Oct 12, 2015 11:56 AM
SeanU
US Northeast
Sep 20, 2015 12:46 PM
chatmanx
Sep 11, 2015 07:17 PM
