Transmission Replace? P0860, P1582, P1643
Had my car in for a service check today, I was thinking the transmission was going out on it. The independent garage (not Jaguar) ran diagnostic checks on it and came back with the following:
P0860
P1582
P1643
And stated I needed to replace the transmission.
I've read almost all the threads for these codes, but have not seen what was the final solution. The car seemed to drive a little better coming home, but I did not "get on it". Any advice on where I should start or what I should do? They quoted me $6,900 to replace the transmission, which I thought seemed awfully high. I called a local shop and they said they could rebuild it for $3,500-$4,500 which sounded reasonable, but I don't have any experience with them.
Car is a 2003 S-Type R with about 173,000 miles on it. Not sure if the transmission has ever been serviced, I purchased it used and have had concerns attempting this myself and have not found a local shop willing to do this with the amount of miles on it.
Thank you!
P0860
P1582
P1643
Thank you!
What kind of symptoms are you experiencing? Those codes seem to lean towards a TCM or J-gate problem more than an internal transmission issue. It may just need re-programming. As always, check the battery first.
Could just as easily be a wiring (harness) or connector problem.
If you haven't, grab (see stickies) the free codes PDF and/or JTIS and see for yourself.
Decide if you want to DIY. Stay away from any mechanic whose idea is a trans replace on so little data.
KarimPA
Sep 3, 2015 07:32 PM
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
Sep 2, 2015 11:43 AM
