transmission thump
Old Nov 14, 2014 | 05:52 PM
Drinkwine47's Avatar
Default transmission thump
Hi everyone
i have a slight problem with my 2005 s type
when i slow down (1 or 2 mph) coming to a light or stop sign.
If i don't come to a full stop before i accelerate, when i accelerate i feel a "lunging" effect and a slight "thump' noise
i thought it might be a brake not releasing at the same time as the other brakes
also i thought it might be the transmission not fully shifting through the cycle quick enough (the transmission performs fine, except for this situation....and it's not all the time
can anybody advise as to what it might be, and offer a solution
thanks
chris p
Old Nov 14, 2014 | 08:16 PM
Mikey's Avatar
Classic signs of 'the lurch'- a very well known problem. A reflash of the transmission software might/might not fix it. There's dozen of posts on the subject.
Old Nov 16, 2014 | 07:39 AM
Jon89's Avatar
Also, an ATF drain-and-fill may or may not improve the issue. As previously mentioned, research "the lurch" here and draw your own conclusion regarding how to proceed. How many miles on your odometer?
Old Nov 18, 2014 | 01:04 PM
joycesjag's Avatar
And to add another scenario, it possibly could be a slight vacuum leak. Have you had the codes read?
Old Nov 19, 2014 | 07:54 AM
just turned to 53,000 miles
chris p
Old Nov 19, 2014 | 07:58 AM
Thanks for the info
i do have a slight emission leak
i'll that checked out first before i proceed with anything else
chris p
Old Nov 19, 2014 | 08:50 AM
joycesjag's Avatar
If you have the 3.0:
https://www.jaguarforums.com/forum/s...ics-faq-52720/
Old Nov 21, 2014 | 11:45 AM
Jimmy 68's Avatar
I have an. '03 so it has the ZF transmission. Lurches sometimes, but when I'm at about half way on the accelerator, when the trans shifts from 1st gear to second , I hear a " whoot" noise!
Have to get trans fluid changed soon, 79k miles now.
Old Nov 21, 2014 | 11:54 AM
Jon89's Avatar
You have the classic "ZF squawk". The clutch packs are grabbing and causing your squawk due to the friction modifiers in your ATF wearing out. An ATF drain-and-fill with the appropriate fluid silences the squawk the vast majority of the time....
Old Nov 21, 2014 | 02:38 PM
Mikey's Avatar
The hoot and lurch are two different dances. There's a third type which is seen at moderate speeds with a cold trans. only.
Each has a different fix.
Old Dec 12, 2014 | 06:14 AM
biffo17's Avatar
ive got the hoot !!! fluid change ??
Old Dec 12, 2014 | 06:27 AM
Timmyboy's Avatar
Do you get a knock when engaging drive or reverse from a stand still?
Old Dec 13, 2014 | 04:59 AM
biffo17's Avatar
hi no no knock ? usually from 3/4th
also the car drives very well when driving normal ( steady pedal)
but if i floor the pedal the car seems to jump out of gear
( or misfire not sure ) then, searches for another gear ??
been to auto specialists just for prelim diagnosis they state its not the tc possible gear selector
any thoughts??
Poet
Feb 7, 2025 02:18 PM
Marka
22
Sep 11, 2016 12:09 AM
JTC3400
Sep 29, 2015 05:03 PM
Old_Doc
Sep 29, 2015 03:43 PM
