Trouble lights on, won't shift out of park
Old Jul 9, 2015 | 02:05 PM
mechemg's Avatar
Default Trouble lights on, won't shift out of park
2006 S-Type 4.2 VDP. All at once. Won't shift out of park, check engine, red and yellow trouble lights on in speedo display plus yellow ABS light on. Also, a continual beeping to further inform me I have a problem. The display showing mpg, range, etc. is blank. Any thoughts?
Old Jul 9, 2015 | 02:34 PM
joycesjag's Avatar
How old is the battery?
Old Jul 9, 2015 | 02:54 PM
mechemg's Avatar
Default Battery
I replaced it a couple of years ago. Seems strong and Jag started fine last winter here in Michigan after 5 weeks not running. (We were in Mexico.)
Old Jul 9, 2015 | 03:57 PM
So it's not starting now?
If so get the battery checked.
Old Jul 9, 2015 | 04:04 PM
mechemg's Avatar
Default Battery's fine
Starts instantly - the battery is strong
Old Jul 9, 2015 | 04:18 PM
joycesjag's Avatar
What are the codes?
Old Jul 10, 2015 | 09:02 AM
mechemg's Avatar
Default No codes
the display where the codes should show remains blank
Old Jul 10, 2015 | 09:16 AM
Perhaps try a hard reset - you never know.
Otherwise you will need to get someone with a code reader to hook it up and check for you.
Old Jul 10, 2015 | 10:42 AM
JagV8's Avatar
The display doesn't show codes - you need an OBD tool. Without getting the codes you're working blind. Tools start at under $10
Old Jul 10, 2015 | 12:44 PM
tbird6's Avatar
Yes get the codes read. We can't help unless we have them.
JarodL
Mar 7, 2024 01:39 AM
Jpav27
Jul 31, 2022 06:43 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
King Charles
Sep 3, 2015 12:40 AM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
