Trunk release
Old May 28, 2008 | 03:53 PM
mep's Avatar
mep
Default Trunk release
I have a 2000 S-type 3.0 and was rear ended last Sept. and needed a new trunk lid. When I open the trunk via the remote the trunk doesn't fully open (can't remember if it did before or not). Is there any kind of adjustment to correct this?
Old May 28, 2008 | 07:08 PM
jag_genius's Avatar
Default RE: Trunk release
old bulletin.. was for adjusting.. the trunk spring.. have to be strong to do it.. ..check 1st..remove plastic screw.. on right side.. and check to see if the spring is set to the farthest away.. there is only 2 settings.. if thats ok then check latch.. may be mushroomed..
Finbarr1975
Sep 5, 2025 08:38 PM
MrWhite
33
Oct 22, 2015 10:29 AM
adam699
Oct 13, 2015 05:53 PM
Lawrence
XJ40 ( XJ81 )
Oct 1, 2015 08:36 AM
