Trying to figure out the transmission?
Old Feb 3, 2013 | 05:51 PM
jagheadache's Avatar
Default Trying to figure out the transmission?
I own a 2005 Jaguar S-type,sport 3.0 and I am having trouble figuring out which transmission gasket fits this car. Also, I need to know how do you replace the transmission fluid lost and is there a special tool used to put it back in since the transmission is supposed to be sealed?
Old Feb 3, 2013 | 07:03 PM
bfsgross's Avatar
Ahrrg! Welcome to S-World. Your 05 S-Type has the ZF 6 speed trans. Using the forum search feauture, read the many threads on ZF trans. issues. If you opt not to heed to my advice then you'll likely recieve the full wrath of jagv8, et al. Your choice....
Old Feb 3, 2013 | 07:34 PM
Mikey's Avatar
RTFM most definitely does not apply in this case!
RTES does though, read the excellent stickies.
https://www.jaguarforums.com/forum/s...-guides-41364/
Old Feb 3, 2013 | 08:14 PM
bfsgross's Avatar
Default 10-4 That!
Ditto to Mikey!
Old Feb 3, 2013 | 09:42 PM
joycesjag's Avatar
jagheadache here you go:
https://www.jaguarforums.com/forum/s...ics-faq-30991/
https://www.jaguarforums.com/forum/s...plained-37802/
If you can DIY, its not as hard as the above links seem.
Old Feb 4, 2013 | 05:08 AM
steveinfrance's Avatar
Make sure you can get the fill plug out before you do anything else.
Get a kit that includes the larger head Torx screws.
Getting the old ones out usually means taking a cold chisel to some of them to make them turn.
If you haven't got a gun-type thermometer I bought a cheap pack of temp sensitive stickers and stuck a couple on the new oil pan.
aholbro1
Dec 29, 2024 06:46 PM
tomsjag
Jun 10, 2023 10:02 AM
Poet
Oct 6, 2015 09:40 PM
mrplow58
Sep 15, 2015 09:58 PM
chatmanx
Sep 11, 2015 07:17 PM
