v6 auto S-Type petrol 2001
Old Aug 16, 2016 | 10:21 AM
cribbox's Avatar
Default v6 auto S-Type petrol 2001
Central locking on o/s/r door not working, Will lock when you lean in over and then use remote to lock all other doors. Told it was the locking unit fault so bought a new one from Jaguar (it is the correct one apparently). Had two car mechanic's (not from Jag) look at it but find no way to take old one out, Tried all sorts. Any thoughts please
Old Aug 16, 2016 | 10:40 AM
Welcome to the forum cribbox,
I've moved your question from General Tech Help to S-Type forum. Members here with the same model will be able to help.
Old Aug 16, 2016 | 11:24 AM
NBCat's Avatar
I assume 'o/s/r' means off-side rear, so the RH rear door when seated in the driver's position?
It may be best to remove the car to a Jaguar specialist, or perform the work yourself. Refer to JTIS for procedure, or download the Workshop Manual pdf from an Internet vendor.
Old Aug 16, 2016 | 07:37 PM
joycesjag's Avatar
If NBCat is correct in his assumption, today is your lucky day:
https://www.jaguarforums.com/forum/s...ics-faq-65657/
Old Aug 17, 2016 | 10:56 AM
NBCat's Avatar
I can certainly understand why you would not want to undertake that repair again!
HarrisTweed
Apr 12, 2016 11:05 PM
robearner
Apr 2, 2016 03:51 PM
Streambed
Mar 29, 2016 09:12 AM
Sep 26, 2006 11:18 AM
