V8 4.2 S-Type 2003 No Spark
Old Mar 9, 2010 | 02:29 AM
mookie30's Avatar
Default V8 4.2 S-Type 2003 No Spark
Hi all, I have a 2003 S-Type with no spark at any of the coil packs, have compression tested and we're all good and there's fuel there just no sprak whatsoever. Before I get it taken away for expensive diagnostics on the ECU/Cam/Crank sensors wondered if anyone knows of a common fault? Have checked the coil pack fuse and it's fine. Cheers!
Old Mar 9, 2010 | 02:45 AM
JagV8's Avatar
It's very rare. If it cranks OK and squirts fuel, it doesn't sound like a PATS fault (a good start). There are probably fault finds / pinpoint test in jtis and on jag's GTR so try those if you'd like to save $$$. Have you at least checked the harnesses are OK and signal is applied to the inputs of the coils? Also, what happened in the time before it died - any symptoms at all?
Do you have a GOOD place you could send it to? You don't want the wrong person making it even worse.
Old Mar 9, 2010 | 02:51 AM
mookie30's Avatar
Thanks for your reply, where do I check the JTIS and the GTR, sorry a bit of a newb at Jags, although I do know my way around cars. Not checked the harnesses as I don't have a wiring diagram to know which wire does what. I do have a Jag specialist who is supposedly the dogs danglies, comes recommended by a couple of people.
Old Mar 9, 2010 | 02:58 AM
JagV8's Avatar
GTR - see jag web site about tech info, takes you to www.jaguartechinfo.com
jtis - ebay, under workshop manual (a search would find you this)
What does your PATS light do at ignition on (watch closely for at least 15 secs; if it flashes count the code) and when you try to start the engine?
It would help in future if you put more details in your profile
I hope your jag guy knows modern, hi-tech jags i.e. electronics & computers as well as old electrical stuff.
Old Mar 9, 2010 | 10:13 AM
mookie30's Avatar
Not sure where the PATS light is, can't see anything flashing after I turn the ignition on. The info display says performance restricted (no crap, it doesn't run!).
caveforce
38
Nov 16, 2015 10:19 AM
Quantico
Oct 13, 2015 10:34 PM
Ipc838
Sep 13, 2015 03:27 PM
joesoap
Sep 10, 2015 01:09 AM
carcycle
Sep 7, 2015 04:14 AM
