Vacuum leak elbow(s)? Car stumbles but no CEL
Old Mar 14, 2012 | 10:33 AM
55chevy's Avatar
Default Vacuum leak elbow(s)? Car stumbles but no CEL
My 2000 3.0 always had a stumble when shifting into 3rd gear, then it got worse and would stumble/stutter at idle, up and down about 50 rpms but never had a CEL. I thought it might be the IMT o-rings and replaced them, it helped a little but not much. I plan to use carb cleaner and check all vacuum lines, in reading a post by Joycesjag about vacuum lines https://www.jaguarforums.com/forum/s...ics-faq-52720/ he mentions two elbows under the intake that are known to leak, a seperate post on jagrepair shows replacing only one elbow, is it one or two?
http://jagrepair.com/VacuumLeakSType2000.htm
Old Mar 14, 2012 | 10:49 AM
Two I believe.
Look at post #5
https://www.jaguarforums.com/forum/s...e-today-42429/
Old Mar 14, 2012 | 11:36 AM
joycesjag's Avatar
Actually there is only 1 elbow under the lower intake on the MYs 1999~2002.
Brutal points it out in the above link from Norri.
Sorry for the confussion.
Old Mar 14, 2012 | 12:09 PM
JagV8's Avatar
But there's a 2nd hose that fairly often leaks, just it's not under the intake - right?
Towards the engine rear I think...
Old Mar 14, 2012 | 12:23 PM
joycesjag's Avatar
JagV8, the most common elbow that leaks is located under the lower intake as Gus points out in this repair: http://jagrepair.com/VacuumLeakSType2000.htm
The 2nd overlooked, I believe would be the brake booster elbow that is located on the backside or firewall side of the upper intake (or plenum), as Brutal suggests in post 5 of this link: https://www.jaguarforums.com/forum/s...e-today-42429/
Old Mar 14, 2012 | 01:15 PM
JagV8's Avatar
Yes, that'll be the 2nd one I expect.
BrentGardner
29
Dec 16, 2024 12:13 AM
rusty37
Jun 7, 2016 04:43 PM
bigpav7
Sep 7, 2015 01:37 AM
SingBlueSilver
Aug 27, 2015 02:20 PM
daro31
Aug 27, 2015 09:26 AM
