valve cover bolt snapped!
Old Sep 2, 2011 | 07:57 PM
boostedhks's Avatar
Default valve cover bolt snapped!
so I was working in putting everything back together after a valve cover gasket replacement on my 3.0 s type and a bolt snapped as I was tightening the bolt. It is the farthest bolt to the left close to the window of the left valve cover (the black one).
What would be the correct procedure to remove this bolt from the engine (the snapped part that stayed in) and where can I buy another bolt like this, it's one of the long ones 10 mm to 8 mm that holds the bracket by the window.
Old Sep 2, 2011 | 08:13 PM
therave's Avatar
hear you go Removing A Broken Bolt Or Stud With A Bolt Extractor - YouTube
how where you tighting it, valve cover only needs 10nm or 7fLb thats not much. looks like you where pulling to hard 6" spanner and your pinkey whould have been ok.
Hope you get it out ok,lots on youtube and toys to get at it..
Old Sep 3, 2011 | 09:46 AM
bfsgross's Avatar
Good suggestion and advice therave. boostedhkf, after removing the valve cover you may realize that there is a good portion of the bolt rising from the head. See if you can get a grip on this and unscrew her. As therave suggests..."lightly" torque her down.
dsnyder586
Dec 29, 2024 07:39 PM
aholbro1
Dec 29, 2024 06:46 PM
bamforp
Aug 14, 2024 05:36 PM
sadepol01
Sep 11, 2015 05:26 AM
jaggermang
Sep 8, 2015 07:07 PM
