Valve Cover Vents
Old Mar 10, 2019 | 07:03 PM
Jay Berman's Avatar
Default Valve Cover Vents
Hello, I have a 2002 S Type 3L - I broke the 2 vents (like PCV valves) on the valve covers, what are they called or what is the hose assembly called? It connects to the air intake
Thank you!
Old Mar 10, 2019 | 08:24 PM
Welcome Jay.
Please do Intro in the New Members Area when the Jag is sorted.
The 2002, is "possibly" what is know as the X200, engine size emblem IN the bonnet (hood), or the X202, emblem actually IN the grille, nothing in the bonnet.
Different PCV system on the 2 models, so different pipes, and part nimbers.
The S Type Tech Section should know, once the model is sorted.
Old Mar 11, 2019 | 03:37 AM
Originally Posted by Jay Berman
I have a 2002 S Type 3L - I broke the 2 vents (like PCV valves) on the valve covers, what are they called or what is the hose assembly called? It connects to the air intake.
Welcome to the forum Jay,
I've moved your question from General Tech Help to S-Type forum. This is the place to post technical questions about your model.
Old Mar 11, 2019 | 08:28 AM
Brutal's Avatar
Part and full load breathers is their name
Old Mar 12, 2019 | 12:40 PM
Jay Berman's Avatar
Thank you .... I cannot find any anything under the hood with that designation, there is a sticker on the body of the left door frame with various codes, it was manufactured May 2001. It appears that there is a PVC valve that has melted on the rear center of the engine with a vacuum line going to the front of the intake manifold and one on each valve cover that go to the air intake right before the throttle body ... Breaking those by removing them seems to be common ...
Old Mar 12, 2019 | 02:26 PM
Brutal's Avatar
Sorry i thought you had a v8. Yeh those suck. If you cant get new ones clean real well and seal them down. Yes with time theyre brittle
Old Mar 12, 2019 | 03:00 PM
S-Type Owner's Avatar
Here you go:
https://www.jaguarclassicparts.com/u...rol-to-vm45254
David Bedoya
Jan 15, 2017 04:12 PM
xjrjag
Jul 9, 2015 01:41 PM
TopHatChef
Apr 28, 2015 01:29 PM
abonano
Jul 17, 2013 08:11 PM
bootleg
Jul 3, 2008 02:45 PM
