Valvoline Max life ATF. $20/gal
Old Feb 5, 2016 | 02:18 PM
car5car's Avatar
Default Valvoline Max life ATF. $20/gal
I used it for Mercedes and Jaguar.
There is info on their web site car/ ATF
Old Feb 5, 2016 | 03:50 PM
JagV8's Avatar
With which of the gearboxes do you say that's compatible?
Old Feb 5, 2016 | 08:33 PM
plums's Avatar
Multiple, but the Merc 722.6 for sure as enumerated
in a Mercedes TSB.
Full product name to avoid confusion:
Valvoline MaxLife Dex/Merc.
Old Feb 6, 2016 | 01:45 AM
JagV8's Avatar
So... which S-Type?
I was meaning that, after all this IS the S-Type forum!
I think it's: none of them. If so, why put the thread on here?
Old Feb 6, 2016 | 04:47 AM
leaping cat's Avatar
It is Mercon V, so it is good for the Ford 5r55n gearbox. I used this for the last two oil changes.
Old Feb 6, 2016 | 06:27 AM
JagV8's Avatar
Is it? I saw it saying LT 71141 which is not Mercon V is it?
Oddly the OP apparently has the ZF 6HP26.
Old Feb 6, 2016 | 09:52 AM
Jon89's Avatar
The safest non-LifeGuard 6 ATF choice for the ZF 6HP26 unit continues to be Mercon SP. It meets the required Shell M1375.4 specs. More and more of us are choosing to use it in our aging ZF units....
Old Feb 6, 2016 | 10:22 AM
car5car's Avatar
If you are interested, you can find info for all cars on Valvoline website. Please post link here if you do.
I used about 2 quarts to add in ZF HP26 transmission.
I am planning to change fluid, that is what I'll use.
Old Feb 6, 2016 | 10:49 AM
JagV8's Avatar
How can this stuff be compatible with Dexron II, Dexron III, Mercon V and Mercon SP???
They're mutually incompatible.
I don't fancy it in a 6HP26.
Old Feb 6, 2016 | 10:53 AM
Mikey's Avatar
Poor car. Are you related to this guy?:
https://www.facebook.com/joe.rooney.9003/videos/1663577117228678/?fref=nf
Old Feb 6, 2016 | 11:13 AM
car5car's Avatar
link
Old Feb 6, 2016 | 11:50 AM
JagV8's Avatar
Read the many posts and see how wrong you are.
Old Feb 6, 2016 | 11:52 AM
Mikey's Avatar
Originally Posted by car5car
Hey, guys, I am sure, the most expensive fluid with bright labels is the best for you!
No, we buy the correct fluid at about the same price as your incorrect fluid.
Old Feb 6, 2016 | 12:24 PM
car5car's Avatar
PDF in post 11
Old Feb 6, 2016 | 12:25 PM
car5car's Avatar
Which one is cheapest correct fluid?
Old Feb 6, 2016 | 01:55 PM
The PDF does claim it's suitable for the ZF.
Old Feb 6, 2016 | 02:43 PM
car5car's Avatar
2002.5-2008 S-type Maxlife, see right column
I believe Valvoline.
Old Feb 6, 2016 | 03:00 PM
plums's Avatar
At least as reasonable as listening to internet experts.
As for the Merc 722.6, since Merc says so themselves
in a TSB, it's a done deal.
Old Feb 6, 2016 | 03:02 PM
plums's Avatar
In a V6?
Old Feb 6, 2016 | 03:06 PM
Yes, the V6 and V8 have the same box.
