Water on the roof under the headliner
today I went around a corner and got a drip of water onto the gear lever . I searched and found it came from the little vent in the roof console. I removed it and found water on the roof between the roof and head liner . Since the summer my head liner has been sagging but just thought it was just the age . I think this could be the reason but my question is where could it be from ? Could it be a build up of condensation or a leak . It was all sitting on the interior of the roof rather than the head liner . The other thing is it doesn't have a sun roof .
Your headliner assembly consists of a fiberglass "form" to which foam a backed material is adhered. The backing form follows the contour of the steel roof. With no sunroof, my first guess would be a leak at the windscreen; has yours been replaced at some point?
not in my ownership but before that I don't know . I have for the last month been using a frost cover that traps in the doors and has rained whilst it's been on a few times . But unsure if that would be a culprit
It is possible that the water is from a leak in the roof, especially if there is no sunroof. It could also be condensation from the air inside the car, which is normal in hot weather. However, it is difficult to determine the exact source of the water without additional inspection. If you are concerned about the source of the water and the condition of your headliner, it is best to contact a professional for a thorough inspection. A professional roofing company like South Dublin Flat Roofing can help you identify the source of the leak and provide you with the necessary repairs to get your roof back in working order.
Welcome, johndep12. I see that the above is your first post. The OP has not been around the forums since June 2021, so he may not see your input.
It is customary (and expected) that new members post a brief "introduction" in the New Members forum, here:
New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
