Weak HVAC blower motor
Old May 23, 2013 | 02:54 PM
Jag944's Avatar
Default Weak HVAC blower motor..SOLVED
Hi, when I use my air conditioning, the air coming from the vents is sooo weak, that it makes me think something is very wrong. I have to have it on full blast to even feel it. Is this normal on the STR to have such weak airflow from the vents with or without using a/c?
I have changed the micron filter, and good air comes from under the foot ducts when I have those on, but the vents flow very poorly.
Other than that, the blower motor is very loud and functioning well otherwise. So this is either a poor design or my car has an issue.
Anyone else?
UPDATE 8/2013: It turns out that my vent solenoids were not working properly. I replaced one of them (the vent one) per the TSB that is floating around here. Now I have full blast AC. I will eventually replace them all.
thanks,
Frank
Old May 23, 2013 | 04:46 PM
JagV8's Avatar
Not normal at all. You've a fault.
SCMike
Nov 25, 2015 07:55 AM
Newark Nj Gang
Oct 2, 2015 02:39 PM
davidboger
Oct 1, 2015 10:13 AM
JagBrian
Oct 1, 2015 12:52 AM
