Webasto Heater,
Old Jan 31, 2012 | 03:09 PM
JagV8's Avatar
Do a Search on diesel and then you'll see very few posts because the diesel was never available in USA/Canada.
The UK forum has plenty, and threads on that very device....
Old Jan 31, 2012 | 03:21 PM
InverStype's Avatar
Originally Posted by JON PIERCE
I am having problems with excessive fumes inside the car, have done lots of searches and found many with the same problem but no cure. Can I simple pull a fuse, disconnect a wire or something to stop it working altogether.
Hi Jon,
I do not know all the details regarding this problem, but there was a modification carried out to overcome this problem. Your Jag dealer will have the details of this, but think it involves revised routing of the exhaust pipe from the heater unit and some other alterations to the fuel feed pipes as well. Reduced in size to allow less fuel into the heater unit.
Check on the UK site, Jaguar Forum.co.uk You should find plenty of information there about this problem. It can be cured that's the good news. Yes some people in the meantime pull the fuse that controls the Webasto Heater which naturally prevents the heater from working.
Regards
Inver.
jazzman20014
Oct 26, 2015 04:15 PM
xjrjag
Oct 12, 2015 03:16 PM
inactualis
Oct 2, 2015 11:13 AM
dickc
Sep 21, 2015 02:04 PM
