Well, apparently I was a dipstick ...
Old Nov 1, 2010 | 09:37 AM
Staatsof's Avatar
Default Well, apparently I was a dipstick ...
So last week I got the dreaded Restricted Performance message and the oval yellow light under it. Yes it's the same GD codes as the last time a couple months ago when they changed the MAF. So into the dealer I go.
Well it turns out that I didn't quite have the dipstick seated tight and that's enough to yield L & R banks too lean. I dumped them at Autozone with their OBD reader. I'm not sure I got the yellow light the last time around though? That would come and go.
I thought the draw from the crankcase was ahead of the MAF so would it still be considered a vacuum leak that could affect the mixture?
My Jag dealer was great about this and I had the automatic door locking turned off at the same time.
Bob S.
Old Nov 1, 2010 | 11:25 AM
sivkov-y's Avatar
This is good info to know/have for the now and the future.
Old Nov 1, 2010 | 02:24 PM
Staatsof's Avatar
Oh you mean "How not to be a dipstick". ;>))
My service advisor said that they've had a few where the O-ring seal started to fail.
Old Nov 1, 2010 | 02:46 PM
tbird6's Avatar
I got this when I started the engine after an oil change. I left the fill cap off and started the engine but the Jag does NOT like this at all!!!
Installed the oil cap and everything was fine.
Old Nov 1, 2010 | 05:14 PM
I did the same thing the only indication was a smell of hot oil, no warning lights at all.
Old Nov 2, 2010 | 10:01 AM
JagV8's Avatar
When I saw the title I hoped you'd figured out a way to add a dipstick to the ZF!
I think the breather (PCV) will be after the MAF to reduce oil vapour contamination of the MAF, which would tend to stop it reading properly.
The CARB/EPA requirements are tough so the car flags all manner of issues - as you just found. Sounds like a decent dealer reaction
Old Nov 2, 2010 | 02:34 PM
sivkov-y's Avatar
No no, you see i am still repairing my STR and am not driving it yet. Thats what I ment by good info for the future. Nothing else implied.
hoodun
May 15, 2019 09:31 PM
studentper
Feb 20, 2016 09:43 PM
inactualis
Oct 2, 2015 11:13 AM
Adriantj
Sep 30, 2015 07:07 PM
black5litre
Sep 27, 2015 03:10 PM
