What are reasons for overheat?????
Old Aug 30, 2007 | 01:20 PM
Igloo112's Avatar
Default What are reasons for overheat?????
I'm having a problem with my car overheating. I recently had the thermostat changed and I'm still having this problem. It doesn't overheat all the time, just sometimes. I would notice the temp needle slowly going past the half mark toward red as I step on the gas. When I take my foot off the gasand keep it off it would slowly go back to half point. Twice the needle went to the red section. When it did that a message came up saying "Engine temp too high". I cut the car off and the engine fan continued spinning. Even when I took the keys out of the car. I guess that's a safty feature or something.
Anyway, I would like to know all possiblereasons for an overheat. Thermostat's been changed. The fan works, and due to the slow rising and falling of the temp needle I would guess that the sensor is working also. The water pump is covered under my warrentee but I haven't had that checked yet. I would like to know if there is anything else before I take it in. Please help. Thanks for reading.
Old Aug 30, 2007 | 03:49 PM
Jose's Avatar
Default RE: What are reasons for overheat?????
I'm not familiar with the modern S type,only with my 1965 S type.
the transmission in modern cars has an oil cooler which is sometimes connected to the radiator to cool the fluid.
Has anybody checked the transmission fluid level? A transmission with not enough fluid will overheat the engine.
A clogged radiator is a possibility but on such a young car I doubt it.
a bad Fan Clutch (one which doesn't disengage when the engine is accelerated).
assuming your car has one.
A bad water pump, but then it would leak through the "weep" hole.
Air bubble in the system, you need to "bleed" the system from air.
To check for air bubbles or to bleed/purge air from cooling system:
Loosenradiator cap to first "detente", (make sure it cannot come off)
Heater Temp all the way to Hot,Heater fan in High.
start and warm engine up to temperature, allowing thermostat to cycle through two or three openings and closings to stabilize system,
Watch as the system "regurgitates" any air for around 20 minutes after reaching normal temp.
you might see a rush of coolant come out from under the cap. Any air is now bled.
Close radiator cap tightly with a rag to avoid burning hand.
When theengine is cold again,(next morning), top up the coolant.
Hope this helps a bit.
Jose
Old Aug 30, 2007 | 04:33 PM
ken@britishparts.com's Avatar
What year and what engine size? Some of the early V8 waterpumps had problems with the plastic empellors. The empellor would erode and eventually move no water.
Old Aug 30, 2007 | 09:33 PM
Igloo112's Avatar
It's a 2000 4.0.
Old Aug 31, 2007 | 09:24 AM
Check the water flow once the car heats up and the thermostat opens. Maybe you have the impellor problem. It's another option.
Old Sep 7, 2007 | 03:42 AM
momo's Avatar
That was a good read chelle26.
oldjaglover
Dec 25, 2024 04:33 PM
Chuck Schexnayder
33
Oct 24, 2015 10:20 PM
LilaJagHubby
Oct 6, 2015 02:56 AM
Stilling
Oct 5, 2015 04:23 PM
Gregory Neil O'Rear
Sep 29, 2015 09:52 AM
