When I drive the A/C is cold but when I stop driving it gets really warm!
Hello Guys ..
I have a problem with my A/C,, which is when I drive the A/C is really cold but when I stop driving it gets really worm!
My car is S-type 2008, I drove only 33K miles!
How can I fix it guys?
My first suggestion would be to start the engine, switch ON the a/c, open the bonnet/hood, and observe that the electric fan is actually working.
In the brief description you give, I strongly believe the fan is NOT working, and the airflow created by he car actually moving is sufficient to cool the condensor, thus giving you cold air. The moment the car stops moving, the airflow also stops, and the condensor can no longer dissipate the heat.
If this is the case, then the reason for the fan being inop needs investigating, and may be the fan motor itself simply worn out. The relay that actually controls the same fan may also be a dud.
Ooooooooooh, THANK YOU very much ..
the fan isn't working, i'll see what can I do to fix it ..
but really I suffered with the a/c technician, the car was with him for 1 week, and he got from me 30 pounds, after all he didn't even know that the fan isn't working !!!
Thank you again ^^
Thank you again ^^
Check out the handbook but I think there are 2 fuses for the fan, one is 80A (other maybe 10A). Both in fuse box in engine bay as I recall. Will also be shown in electrical guide / JTIS - free download on here.
I had the same problem with the a/c only blowing cold air when the car was driving. I ended up fixing the problem with the TSB specified in post number 4 in the thread posted below:
https://www.jaguarforums.com/forum/s...ng-idle-59122/
Thank you guys
I fixed it as you suggested by the TSB
https://www.jaguarforums.com/forum/a...b00183nas1-pdf
I saved 1000 pound
Thanks again.
I saved 1000 pound
Thanks again.
My A/C stopped working on my 04 STR a week ago. I've been reading all the posts and slowly eliminating failure points one-by-one. Since the lines aren't feeling cold and the lower port below the fender well is reading high pressure, at about 100psi, I am suspecting either the pump or the valve in the pump has failed. Not something I need to have to fix right now. I am pretty sure my DCCV is working properly.
Grumble-grumble......
Thank you guys
I saved 1000 pound
Thanks again.
I saved 1000 pound
Thanks again.
