Where Is The Fuel/Vapor Canister Located On A 2006 Jaguar S-Type 3.0
Old Jun 1, 2018 | 04:30 PM
Redbottominc1's Avatar
Default Where Is The Fuel/Vapor Canister Located On A 2006 Jaguar S-Type 3.0
I Am Doing A DIY job on a 2006 Jaguar S Type 3.0 in I am getting the P240B and P2401 codes . The car runs strong but at idle the car sounds like it is sputtering ? HELP PLS THANKS IN ADVANCE GENUIS
Old Jun 1, 2018 | 04:41 PM
NBCat's Avatar
Refer to section 303-13, page 1788:
http://www.jagrepair.com/images/Auto...M-Workshop.pdf
Default 2006 Jaguar S Type 3.0 Codes P0414 P0031 P240B
I Am Doing A DIY jobs on a 2006 Jaguar S Type 3.0 in I am getting the P240B P2401 P0031 P240B P0414 codes . The car runs strong but at idle the car sounds like it is sputtering ? HELP PLS THANKS IN ADVANCE GENUIS
(Spark Plugs , Coils, And Upper aint ale Gaskets Is New)
The car cuts on in drive regular when car is accelerating.
The car also some times and almost every other time act like it wants to cut off when I come to a hard stop but it catches itself some times or sometimes it cuts off then when the car is restarted , it cuts right back on . Thanks I’m advance again
P0414- Secondary Air Injection System Switching Valve A Circuit Shorted.
P0031- H02S Heater Control Circuit Low Bank 1 Sensor 1.
P240B- Evaporative Emission System Leak Detection Pump Heater Control Circuit Low
P2401- Evaporative Emission System Leak Detection Pump Control Circuit Low
Old Jun 1, 2018 | 04:42 PM
NBCat's Avatar
Use OBD port to determine STFTs and LTFTs. Post them here.
Old Jun 1, 2018 | 05:29 PM
I only have the regular obd scanner . I will try to find a shop who does that because that do sounds like it need that type of diagnosis. Car sputters like a lemon . But when the car is in driving raising rpms it has good speed
SirJohn
Jul 10, 2024 03:58 PM
Redbottominc1
Jun 2, 2018 06:44 AM
Greencar89
Jul 24, 2017 08:28 AM
mbates50
Feb 10, 2016 03:59 PM
J_C_R
May 17, 2013 12:18 AM
