wife leaving..my project list!!
Old Mar 2, 2011 | 09:15 PM
fergs03R's Avatar
Default wife leaving..my project list!!
for a week on a trip with her sister,
I have everything stealithly on its way for a nice upgrade of the STR
Mafiosos intake(today)
Mina exhaust, tomorrow
Pulley, next week
plugs and oil..whenever
clear side markers, tomorrow
however, i have also been extensively reading about the zf trans and the kit from klause
I have zero leaks and the trans operates perfectly but i have 62K on her
do i really need to do the whole kit and drop/replace the pan thing..or what about just doing the fluid. i know its a matter of choice. I have no issue doing that whole project myself, im adept..but is it a do it now or later period, or is it a , do the fluid only if there are no other issues type of thing
Old Mar 2, 2011 | 10:11 PM
bfsgross's Avatar
fergs, you the man! Your STR will be transformed. Are ya gunna do hi-flo cats? 60K? leave the trans alone.
Old Mar 2, 2011 | 10:13 PM
jag79's Avatar
LOLz..I think we are Triplets! All 3 of our STR's are Silver and Charcoal
Old Mar 2, 2011 | 10:49 PM
Spitfire's Avatar
That's all I have to say.
Old Mar 2, 2011 | 10:53 PM
fergs03R's Avatar
no on the cats for now....timing bro timing....
Old Mar 2, 2011 | 10:54 PM
fergs03R's Avatar
soaking in the respect...thanks!!
Old Mar 3, 2011 | 06:34 AM
bfsgross's Avatar
fergs, when yer ready for hi-flo cats read up on the threads. In a week my STR is going in for: remove 1.5 lb pulley, pop on 3 lb pulley, bypass TB coolant lines, intake elbow, NGK plugs, possibly an ECU tune. Off to the dyno from there. Very exciting developments are happening with the STR from guys such as yourself and Mad Man Mafioso (MMM).
Old Mar 3, 2011 | 11:23 AM
fergs03R's Avatar
hey....have you looked at the denso plugs vs the ngk..the denso are a 4 mm tip with a groove vs the 6mm on the ngk... 4mm means less resisence = better spark ...denso more $$ but something to think about.....also , you said to leave my trans alone....I assume you mean leave the pan on and dont do that kit project...but I still should change the fluid I would think yes??
Old Mar 3, 2011 | 01:20 PM
jag79's Avatar
Both the NGK and Denso Iridiums are of 4mm gap bro, take a look here on Rockauto and fill in the blanks to get to all the spark plugs to view.
http://www.rockauto.com/catalog/raframecatalog.php.
Personally I would stick with the NGK's
Old Mar 3, 2011 | 02:24 PM
Jon89's Avatar
ZF tech support in Chicago has advised me to leave our perfectly-functioning transmission alone until at least 80,000 miles. Of course, developing the dreaded sleeve leak would change that plan pronto. But at just under 57,000 miles right now, I'm taking ZF tech support's advice. That advice is based upon a 50/50 mix of highway/city driving, no towing, no dirt or gravel roads, and no hot-rodding. Make your own judgments based upon where and how you happen to drive....
Old Mar 3, 2011 | 03:55 PM
fergs03R's Avatar
Negative..NGK 0.6 mm laser welded electrode
Denso 0.4 mm...worlds smallest..thats their selling point
Old Mar 3, 2011 | 04:34 PM
jag79's Avatar
LOlzz...bro I guess the Denso's got some competition then because I searched all around before I bought my NGK's and used Rockauto.com as my reference when I bought my NGK iridiums from them, it list the Denso and NGK iridiums both at a gap of 0.4mm for our STR's I'm not sure which NGK you are looking that has a gap of .6mm.
Click here, our NGK iridium stock# for our STR is 7886 (0.40mm) & Denso iridium #3356 which actually shows it has a gap of .044mm; Sparkplugs chart-->http://www.sparkplugs.com/results_app.asp?aaia=1410635
Old Mar 3, 2011 | 05:04 PM
fergs03R's Avatar
Click here, our NGK stock# for our STR is 7886; Sparkplugs chart-->http://www.sparkplugs.com/results_app.asp?aaia=1410635
both of the company web sites give their specs.....also not sure why you keep saying "gap" of .04mm...that has nothing to do with the size of the electrode
Old Mar 3, 2011 | 05:09 PM
fergs03R's Avatar
actually i see..you are miss understanding what i am referering to. Im not talking abut how the plug is gapped .040 or .044 etc....im talking abut the thickness of the electrode of each plug...denso is the thinest @ 0.4mm..no worries
Old Mar 3, 2011 | 05:11 PM
It looks like you two have got your wires crossed between air gap dimensions and elctrode diameters.
jag79 those gaps are in inches 0.040" would be 1mm.
Old Mar 3, 2011 | 05:18 PM
fergs,
When are you going to fit in the painting and the rest of the honeydo list?
Old Mar 3, 2011 | 05:23 PM
fergs03R's Avatar
Originally Posted by norri
fergs,
how bout the bathroom going in the basement...that enough of a list
Old Mar 3, 2011 | 05:42 PM
jag79's Avatar
My bad I thought you were referring to the Gap size and that too I was stating it in Inches .040" (1.016mm).
Since the Denso's are at .4mm like you mentioned being the thinnest as compared to NGK's at .7mm at the center electrode. The only thing negative about the Denso's would be that the NGK .7mm plugs will last you 100k before replacement, while the Denso .4mm plugs will last you 60k. Both are elite sparkplugs no doubt and even the newer jaguar XF's are now having NGK spark plugs as OEM.
Take it easy. and good luck!
Old Mar 4, 2011 | 12:17 AM
Bull27's Avatar
******remove leaper with a badge.
forgot that one, nothing but compliments.
Old Mar 4, 2011 | 07:49 AM
JagV8's Avatar
Aren't the OE STR plugs Denso and 100K miles between changes?
