Window Problem on 03 S-type V6
Old Jan 22, 2021 | 05:11 PM
mcube's Avatar
Default Window Problem on 03 S-type V6
Hello
I had a problem on driver side window, it stopped working at one time and after few month, it went down itself and doesn't come back on.
So decided to fix it now, replaced regulator and the motor, didn't work.
I replaced master switch but doesn't work on all other windows, only the memory seat is working fine.
Old master switch works on other windows but the driver side.
Is there any reset to program the switch?
I'm stuck on this, please help.
Old Jan 22, 2021 | 05:13 PM
mcube's Avatar
FYI, I replaced switch because I smell something burnt from it.
Old Jan 23, 2021 | 06:48 AM
Blwn Jag's Avatar
Sounds like you could have a short in your wire loom somewhere. I'd check it out with a VOM. If you smell something burnt... It might not be just from your switch.
Old Jan 23, 2021 | 10:03 AM
mcube's Avatar
I'm tracking all the wires. I haven't seen any damage so far.
The thing is old switch is working (partially) but the new one doesn't.
Tried to calibrate it with so many different ways but didn't have chance to get it.
Old Jan 23, 2021 | 11:34 AM
S-Type Owner's Avatar
Is the switch new, or a used part from that famous auction site? Also, is it exactly the same part # as the original switch that was removed?
Old Jan 23, 2021 | 12:19 PM
mcube's Avatar
I got used switch from local Jaguar specialist shop. The guy told me all their electric parts are tested.
Switch didn't have the part number so I opened it up and compare with old one and everything matches even the circuit board.
10 XF Premium
Oct 11, 2018 11:03 AM
RFXJ12
Oct 18, 2015 04:43 PM
OldSpanner
Feb 18, 2015 03:37 PM
Rutty
XJ40 ( XJ81 )
Jan 20, 2014 04:06 PM
Hartleys
Nov 16, 2012 07:12 AM
