window trim issue and sunroof piece broken
Old Aug 23, 2011 | 09:39 PM
gagashby's Avatar
Default window trim issue and sunroof piece broken
on my str the black window trim on my driver side is pulled away from the door, is there anyway to fix this? also my sunroof in one corner was always low, i tried to reset the sunroof didnt work. so i took it off and on the drivers side the piece that lifts the sunroof in tilt mode a little bit of the tip was broke off letting the slider just roam free, is there a part number for this or a site to buy it from? thanks!
Attached Thumbnails window trim issue and sunroof piece broken-photo-14.jpg   window trim issue and sunroof piece broken-photo-15.jpg
Old Aug 24, 2011 | 02:49 AM
Cadillac's Avatar
Old Aug 24, 2011 | 03:55 AM
gagashby's Avatar
thank you for all the sources i really appreciate it! but i dont know what the plastic piece is so i dont know how to search for it, thanks again!
Old Aug 24, 2011 | 05:03 AM
joycesjag's Avatar
Try this link for the window trim, it explains how to remove and reattach: https://www.jaguarforums.com/forum/s...ics-faq-29860/
Regent has you covered for the moonroof. BTW there is an adjustment procedure to manually level it after you replace the broken piece.
Good luck
Old Aug 24, 2011 | 10:07 AM
Mafioso's Avatar
For what its worth. I just replaced both driver side black trims, and I dont mind parting with the old ones, they are straight and in 8 out of 10 shape. If yours are bent.
Old Aug 24, 2011 | 12:27 PM
tbird6's Avatar
How come you changed them out? Did you go to the shiny version?
Old Aug 24, 2011 | 12:50 PM
Mafioso's Avatar
No sir, we got a nasty hail storm in Dallas, and I was caught in the middle so the insurance deemed they needed to be replaced because the rubber underneath was old brittle.
99xk8guy
Sep 29, 2025 10:51 PM
JarodL
Mar 7, 2024 01:39 AM
pocketrocket
Sep 3, 2015 07:44 PM
King Charles
Sep 3, 2015 12:40 AM
OkieTim
Sep 2, 2015 12:48 PM
