windshield fluid pump
According to JTIS, you have to remove the radiator splash shield (plastic cover between the bottom of the bumper cover and radiator with a bunch of screws holding it in place), remove the hose and electrical connector from the pump, then pull the pump off of the tank. Replace in reverse order. Looks like a very easy job.
Mark
Mark
without the engine running but ingition on..hit the washers and listen by the reservoir. do you hear it running? if not replace the pump or check for signal at the connector, hate to see you replace a pump for a supply fault. and the clog is useally at the inlet of the pump from sediment in the tank. if you hear it run but doesnt work then pull the pump and clean out the inlet with compressed air.
No if theres no sound, just verify with a test liight you have power and ground to the pump when you press wash other wise yes replace it..just didnt want to see you throw parts at it needlessly
FS[SouthWest]: Red 2001 XK8 Convertible in Colorado
picard
Oct 12, 2015 11:56 AM
chatmanx
Sep 11, 2015 07:17 PM
1964Daimler
Sep 9, 2015 11:28 AM
