windshield pillar trim removeal
Old Jan 31, 2023 | 10:56 AM
capt's Avatar
Default windshield pillar trim removeal
I have a code 17 air bag, is it ok to remove trim to check connection without disconnecting battery? Is there any thing else to look for?
Thanks!
Old Feb 7, 2023 | 03:47 AM
LLLA's Avatar
If you are just pulling the trim piece off to visually inspect the wiring, you should not need to disconnect the battery for this.
However, if you need to touch any connectors (even just a quick wiggle to make sure it’s seated properly) then yes, most would advise to disconnect the battery.
I’ve been told leaving the battery disconnected for over an hour should render the airbag modules safe to work with. I have also seen people remove their battery and jump the positive/negative leads to force any residual charge out. I cannot specifically speak to S-Types; but leaving the battery disconnected overnight is the generally accepted safest option.
Considering the cost of a replacement unit and the possibility of getting a face full of plastic, I would disconnect it for at least a few hours.
If you’ve ever worked on CRT monitors or TVs, you’ll know why.
Please be careful is all.
Old Feb 7, 2023 | 07:41 AM
joycesjag's Avatar
Capt, I had the code, years ago. I removed the pillar cover and notice the sensor wiring had broken for some unknown reason. I did disconnect the battery to make zero cost repair. After repair connect battery, clear code, Bob's your uncle.
Old Feb 24, 2023 | 10:09 AM
capt's Avatar
I unplugged the connector, looked ok and reinstalled but no change.
Old Feb 24, 2023 | 11:49 AM
joycesjag's Avatar
If I recall correctly. The wire somehow was broken before the sensor location in pillar. It was awhile ago.
Old Feb 24, 2023 | 01:09 PM
clubairth1's Avatar
Community Influencer
What does code 17 mean? I see that it concerns the Occupant Position System which is NOT the air bags??
I would do some more research before taking anything apart.
David Meier
Mar 13, 2023 10:29 AM
NathanDD6
Nov 22, 2016 04:55 PM
Striker27
Sep 13, 2015 01:57 PM
Dennis07
Mar 10, 2014 06:41 PM
man7sell
Jul 16, 2009 07:57 PM
