Wiper Arm - 2003 S-Type (Fixed)
Old Mar 14, 2012 | 01:51 PM
tferraro's Avatar
Default Wiper Arm - 2003 S-Type (Fixed)
I have a wiper arm on the passenger side that tries very hard to wipe the windshield but it only moves about 3 inches. Since its trying to move can I assume its not the motor and that the arm is stripped and I just need a new arm? If so, where would you recommend buying a wiper arm online? I called my local dealer which is 2 hrs away and they can order one in for $40.00..
Thanks for your time.
Antonio
Old Mar 14, 2012 | 01:59 PM
Have you checked the locking nut?
Make sure that is just the arm that is damaged before you go too far.
Old Mar 14, 2012 | 02:01 PM
tferraro's Avatar
I acctually have not checked that at this point. I haven't even figured out how to get the dang arm off yet. Any insight on this would be helpful if you have time.
Thanks!
Old Mar 14, 2012 | 02:45 PM
There may or may not be a plastic plug on the top of the arm mounting, pop it off and you will find an M10 nut (13mm spanner/socket) take that off then you can use a puller or a lever to get the arm of the spindle taper, hopefully you will find something loose here and the linkage will be in good shape.
Old Mar 14, 2012 | 03:17 PM
tferraro's Avatar
Thanks so much! After work I will try that out.
Old Mar 15, 2012 | 08:30 AM
tferraro's Avatar
I wanted to update you and let you know that I followed what you told me to do and come to find out once I took the plastic plug off, I found that the nut was really loose. I tightned it and it works like magic. Thanks so much for your help. I love this board.
Old Mar 15, 2012 | 03:26 PM
carfix's Avatar
A great result! It is great when a fix is so quick and simple.
I wish all jobs could be the same.
Shawn Svacha
Nov 4, 2019 02:47 PM
neruda
Oct 18, 2015 01:19 PM
OkieTim
Sep 8, 2015 04:48 PM
Harry Dredge
Sep 3, 2015 03:04 AM
XJsc-guy
Sep 2, 2015 11:43 AM
