Wiring by diagram for seats from 2007 S-Type
Old Dec 31, 2017 | 11:55 AM
Chris123's Avatar
Default Wiring by diagram for seats from 2007 S-Type
ive mounted a set of seats from a 2007 S-type into my 1974 Toyota LandCruiser and I'm hoping someone could source me the wiring diagram before I start putting power to these seats. There's a lot in them I could potentially F. Up. Thanks!
Old Dec 31, 2017 | 12:01 PM
Chris123's Avatar
Old Dec 31, 2017 | 01:23 PM
Welcome to the forum Chris,
I've moved your question from General Tech Help to S-Type forum. Members here with this same model will be able to help.
Old Jan 1, 2018 | 12:12 PM
JagV8's Avatar
They're a free download on this site or JagRepair.com - Jaguar Repair Information Resource
Old Jan 2, 2018 | 10:17 AM
Joedotcom's Avatar
hi
there's the 10 way and 16 way adjustable ones, your look like the 10 way
I can attach a wiring pic, but I dont think they will work, the seats have a module in them, which talks to the car via canbus and usualy have to be coded to the car, so even if you power it up I dont think it will work
as they have to be calibrated if a new module is fitted, via jaguar ids/sdd software
cheers
Joe
Old Jan 2, 2018 | 11:36 AM
kr98664's Avatar
With some creative wiring, you may be able to eliminate the module and run the individual motors directly from the switches. You'd have no memory recall, but you should be able to get the motors to run. You'd also have no limit switches for end of travel, so you'd have to make sure to release the switch when motion stops and the motor starts to labor.
One slight hitch is the motors may draw more current than the switches can handle. In that case, you'd have to use relays to handle the current.
WhiteKitty
Aug 25, 2013 07:47 AM
captainfrank51
May 14, 2012 12:25 PM
invicta
Interior
Aug 23, 2009 10:48 PM
LTSBRN1
Oct 6, 2008 07:43 PM
