Working on DCCV and supercharger cooling
Old Aug 6, 2019 | 11:14 AM
Aarcuda's Avatar
Default Working on DCCV and supercharger cooling
On my ‘06 STR, the car was going into restricted performance when I floored it. Ran the codes and got codes for lean banks 1 and 2 and one for IAT too hot.
Found my pump for the supercharger wasnt running. Removed pump and connected it to 12v and its good. Got the schematics and I have a question about the wire colors. Schematic shows intercooler pump wires are white w green tracer and black. But the wites coming off my intercooler pump are white with a black tracer and black with a red tracer. I went and got the upgraded bosch pump aso i cut the cable off the olde pump and got the mercedes connector and pins to make an adapter cable.
But the schematic shows intercooler pump wire (wite w green) goes to 117E. 117E goes to fuse F36. F36 gets power from relay R8. I need to track that down more as im having a hard time finding power there. So more to come later.
On the DCCV issue. I have 14v on the center pin of the DCCV but I only measure 5.8v from center pin on DCCV to outer pins. So I went to the RCCM and found its already been modified by jaguarclimatecontrol.com but its not working. So I ordered another RCCM and once I get it ill install the resettable fuses jaguarclimatecontrol.com added and cut the traces on the board.
I did check the dccv and its good drawing only .9A. Here are some pics
Intercooler pump wire colors
Aux cooling pump wire colors
Cable off original intercooler pump
Wire colors on original intercooler pump.
Old Aug 6, 2019 | 11:16 AM
Aarcuda's Avatar
Rccm
Dead modified RCCM
Resettable fuses
Modified RCCM
pics
Old Aug 6, 2019 | 12:14 PM
scottjh9's Avatar
Did you check the pins on the plug....the one i am referring to is the plug located where the cooling fan and dccv plug are located....there are 3 plug connectors in that location...when i lost intercooler pump operation, i found 3 pins corroded and not making contact....i traced the pump wires to that plug and found them that way
Old Aug 6, 2019 | 12:55 PM
Aarcuda's Avatar
Yes I did check it and at the momsnt I cant remember what I got. An old friend died Saturday and my heads a mess. I dont remember much of what I checked now and will do it again this weekend.
But I noticed corrosion on my pins and spent a lit of time cleaning them up with oxalic acid and baking soda and water and a brush. It nat have been corrosion though bc it was found.
On a different note, someone has been in there before me as all the wiring was zip tied to the aluminum bracket under there and all the wiring connections were under the frame where it would be exposed to water and possibly debris. Id thought the wires woulf be tucked up on top of the front rail instead of under it.
anyone have a harness routing drawing?
Old Aug 6, 2019 | 01:14 PM
scottjh9's Avatar
Originally those plugs are held in a giant clip....most often that clip breaks apart when removing the plugs.....my corrosion led to broken pins .,...i cut and spliced the bad ones. Sorry to hear about your loss....keep positive as best you can....your car will be there as you are ready
Old Aug 6, 2019 | 01:25 PM
scottjh9's Avatar
Check out this thread title..... intercooler pump not coming on 2004 XJR......might help
ccc
71
Apr 27, 2024 10:04 PM
chargerrich
Jul 3, 2023 02:54 PM
M12345678
Jul 14, 2016 12:49 PM
Kevlar9281
28
Mar 16, 2016 12:07 AM
Garrick
Nov 5, 2009 07:31 PM
