Yaw Sensor
Old Jan 28, 2023 | 10:23 AM
jacobjl's Avatar
Default Yaw Sensor
Hi Everyone,
Around 2 years ago I purchased a 2005 Jaguar S-type 3.0 V6 for my first car. I've loved it so far and couldn't imagine driving a different car now, and am hoping it will be the first Jag of many. I've put nearly 40,000km's on it since I first purchased it, and have had almost no problems with it.
Recently however, my yaw rate sensor has failed leaving me looking for a replacement. I was hoping someone might be able to provide some advice as to which part number is compatible with my car. The part most places seem to stock seems to be the C2C34671 which is generally listed as being compatible with almost every S-type from 2000-2008, however I'm quite sure this is a more recent part than the one originally fitted to my vehicle, which I think is a C2C13790. My guess would be that while the C2C3671 is a newer part, it is backwards compatible with the models that did not have it originally fitted however, I was hoping someone might be able to confirm this for me before I ordered the part. I'm probably going to order the part myself, but will have it fitted when I next take my car to be serviced rather than fitting it myself.
Thanks in advance
Old Jan 29, 2023 | 03:40 AM
Sportston's Avatar
That sounds interesting. How does a yaw rate sensor work? I’ve not heard of one of those before.
Old Jan 29, 2023 | 04:10 AM
jacobjl's Avatar
My understanding is the sensor is used to compare the actual movement and sway of the car to the input from the steering wheel and thus determine whether the car is obeying your input, and if not the DSC system can brake a wheel, or reduce engine torque. I'm sure there is someone here that can explain it better than I, and I know the DSC system also uses other sensors such as wheel speed sensors.
Old Jan 29, 2023 | 07:39 AM
S-Type Owner's Avatar
Jaguar Land Rover Classic indicates that indeed C2C34671 is the correct part for your S-type:
C2C34671 - Jaguar Yaw rate sensor | Jaguar Land Rover Classic Parts
I have a vague recollection that this unit must be calibrated to the car and is not just a "drop in" replacement. Hopefully, one of our resident SDD/IDS mavens can confirm this.
Sid216
Dec 2, 2021 05:22 PM
racJAG204
Nov 18, 2018 08:37 AM
PatrickO
Mar 9, 2017 07:17 AM
Ludovic Card
Jul 2, 2016 09:17 AM
chris-jag
Dec 31, 2015 07:02 AM
