You got me stumped
Old Jun 17, 2020 | 06:22 PM
oldtvman's Avatar
Default You got me stumped
Good day,
I had a coolant leak and one of the top hoses behind the reservoir tank had a hole in it. Replaced it, put everything back together, drove it tonight to the store about 4 miles each way, checked for leaks, everything looked good, went out to the garage after about 1 1/2 hours, and there was coolant under the car again.
Any ideas?
Old Jun 18, 2020 | 04:16 AM
JagV8's Avatar
It's wet & red so a light, mirror etc and go hunting.
Old Jun 18, 2020 | 08:35 AM
kr98664's Avatar
My advice from nearly a year ago hasn't changed, post #10 here:
https://www.jaguarforums.com/forum/s...3/#post2117232
Get thee a coolant system pressure tester. Many parts stores offer them as free loaners. You're working blind without one. Don't rely on what you see running when the engine at idle, as the pressure is very low then. You need a tester to fully tax the system and aggravate any weak spots.
My best guess is you've got more than one leak. Maybe the first one only leaked above 5 psi, and the second one only above 10. The second one was never obvious because pressure was continually venting from the first leak. You fixed that, and now pressure builds high enough for the second one to leak. You've fixed one problem. Continue troubleshooting and look for a second problem.
JaguarLover101
Jul 5, 2016 06:14 PM
platinummaker
Jul 11, 2015 10:12 AM
jahummer
25
Apr 11, 2013 06:57 AM
mattlowe
Apr 19, 2010 12:29 PM
mattlowe
Apr 18, 2010 06:40 AM
