Your experiences with Magnaflow 59975 cats?
Old Jan 20, 2012 | 06:17 PM
rasputin's Avatar
Originally Posted by Doryphoros86
Was wondering around the XK subforum, and headed over to the Nameless Performance website. It looks like they finally developed a set of downpipes w/cats for the STR. A little spendy, but the XK guys swear by them.
2002-2008 Jaguar S-Type R Downpipes - Nameless Performance
I paid $150 for my cats, that price is a bit excessive. Dyno numbers speak for themselves though...
Old Jan 20, 2012 | 06:26 PM
vance580's Avatar
There is a post floating around with pics of the Nameless system. The donor car for them to fab that up belongs to a forum member and he posted up pics after they made it for his car.
Old Jan 24, 2012 | 06:32 PM
zetecstr101's Avatar
i see on magnaflow that they also have a 2.5 (59976) and 3" (59979) size cats, can those be fitted and the o2 sensor without any issues?
Old Jan 24, 2012 | 08:46 PM
bfsgross's Avatar
I run the 2.5" inlet/outlet Magnaflows w/O2 sensors; no problems.
Old Jan 24, 2012 | 11:41 PM
03Xtype's Avatar
I just got the 59975 cats in today. They are very small and light weight. they look like they would flow very well. I did notice it saying pre obd2 but if it cleans the exhaust good enough to pass smog I will be happy.
Old Jan 25, 2012 | 06:24 AM
bfsgross's Avatar
Oh, they'll pass smog allright, and yer STR will come to life too.
Old Jan 25, 2012 | 09:50 AM
03Xtype's Avatar
I cant wait. I haven't floored the car since I bought it in fear of having a plugged cat.
Old Jan 25, 2012 | 01:07 PM
  #28
Bacardi 151's Avatar
Where are these dyno numbers? Price is baffling high, especially considering if you have a clogged cat, odds are you'll need to add some serious heat to the exhaust manifold studs to free the downpipe...
Old Feb 23, 2013 | 01:58 AM
faiswish's Avatar
hi guys anybody can tell me if i install universal catalytic converter on my jaguar s type 2004 will this turn check engien light off?
Old Feb 23, 2013 | 04:26 AM
  #30
JagV8's Avatar
What codes are there?
What are your fuel trims?
Old Nov 23, 2013 | 09:44 AM
  #31
Tijoe's Avatar
I am bringing this thread back to life partially to ask if others are having their Magna Flow high flow cats go bad after 30K miles.
My STR had Magna Flow cats installed in late 2010, and I believe that at least one is going bad. (P0420 error code and occasional "Restricted Performance" message.)
I've read in other forums that "after market" high flow cats don't last that long.
True?
Old Nov 23, 2013 | 11:39 AM
  #32
rasputin's Avatar
I have approximately 13k miles on mine and they are fine. Not sure who has put 30k on theirs on this forum.
Old Mar 18, 2014 | 05:43 PM
  #33
Wuzupez's Avatar
Anyone ever remove cats completely and have pipes made to go in place of them? Anyone ever gut the cats and reinstall them hollowed out? If you use O2 sensor spacers on the rear O2 sensors to pull them out of the exhaust flow, it shouldn't kick any codes. As long as the rear O2 sensor reads different than the front your good! Just curious if anyone has done this and how it sounds and performs? If high flow cats make that much of a difference then no cats at all should make a huge difference!
Old Mar 18, 2014 | 07:21 PM
  #34
JagV8's Avatar
Just thinking but:
1. the back pressure will be far too low
2. the O2 sensors will be harder than that, but maybe not much harder
3. it really is not going to free up much power at all and if #1 is right it will reduce power
4. dyno before, try it, dyno after, report back - no-one's tried it
Old Mar 18, 2014 | 09:35 PM
  #35
QuartzSTypeR's Avatar
I think Michael Star was running test pipes with no cats. As mentioned, the hp gains are going to be very small and likely will cost you some low end torque if you go completely catless. A 3# pulley, high flow or no cats and an intake elbow will net you at best 40 hp at the wheels.
Old Mar 19, 2014 | 09:15 AM
  #36
Wuzupez's Avatar
Decisions decisions...... I'm so up in the air on what direction I wanna take this.
Old Mar 19, 2014 | 01:15 PM
  #37
rasputin's Avatar
Instead just do an elbow, 1.5 lb pulley, Mina cat back and save up $$'s for repairs. Don't mess with the cats.
Old Mar 19, 2014 | 01:49 PM
  #38
GT42R's Avatar
I want to swap my cats out this year, or delete them entirely... The o2 sensor spacers should eliminate any CEL issues,
Thinking magnaflow or vibrant for the high flow cats...
Aus V8S
Nov 13, 2015 11:01 AM
Stuart@VelocityAP
Sep 23, 2015 02:13 PM
hoodun
Sep 23, 2015 12:17 PM
Safari
Sep 14, 2015 10:29 AM
rachelstr
Sep 3, 2015 12:59 PM
