ZF 6HP26 trans fill temp explained
Old Oct 20, 2010 | 05:44 PM
Originally Posted by zogg
I m a real JAG newby....just bought a 2006 S type yesterday....
I have a question based upon the above.
What would be wrong with draining the 7.5 quarts, refilling with 4 quarts (engine off) and then starting the engine and adding only 3 quarts....
Does this not accomplish the same thing...am I missing something???
Please advise.
Dave
Ignoring the maths error you would be pretty close, but my understanding of the whole temp check procedure is that pretty close is not close enough.
I'd imagine that most people will choose to drop the pan and replace it with a new one c/w filter bringing in another element along with the dripping that Brutal mentioned.
As for an IR target I'd favour the pan as the heat transfer through the plastic may be better than through the case.
Old Oct 31, 2010 | 10:56 PM
georgekale's Avatar
Good info
Thanks, Guys.
Old Nov 2, 2010 | 07:17 AM
uropnm6's Avatar
Once again another good write up. I am going to change mine, I have 51000 on my 2004 STR thanks Paul
Old Feb 8, 2011 | 10:28 AM
jag79's Avatar
Originally Posted by ntabler90
Hey guys I new to the forums. I have a 2005 S-Type Jag that I just replaced trans cooler lines. Prior to the replacement I would have a small drip on the ground. After changing the lines and reading the begining of this post, I took out the check plug while the engine was running and afer I went through all the gears. How much fluid settles in the plug neck, about?
Take a look at this; Most easiest explanation there is.
File Type: pdf
Old Mar 5, 2011 | 02:03 AM
Scottyobmu's Avatar
I'm still a newbie sorta also lol, just to b sure, this is something I can do to my 2000 s-type 4.0 correct?
Old Mar 5, 2011 | 05:43 AM
JagV8's Avatar
Welcome. And: No. You don't have the ZF 6HP26. Yours is the Ford 5R55N. (The FAQs and Search will get you good threads.)
Old Mar 6, 2011 | 10:11 AM
  #28
Scottyobmu's Avatar
Ok thanks!!! Yeah I'm trying to get use to the abundance of info here lol a lot of great stuff, a little overwhelming, but degjnately great stuff!
Old Jan 18, 2012 | 07:13 PM
03Xtype's Avatar
I would have to disagree with the 7.5L amount.
After letting the fluid drain for 24 hours I removed 4.9L and refilled 5.4L at 41 Degree's on a perfectly level vehicle.
I'm sure thats why the kit only comes with 6L
Old Jan 18, 2012 | 10:32 PM
  #30
DavidRey's Avatar
This guy did his own transmission pan/filter change on his xk8 him self and put it on you tube. Don't know if he did it right but check the video out.
Jaguar XK8 Transmission Fluid/Pan Change - YouTube
Old Jan 19, 2012 | 12:00 AM
  #31
03Xtype's Avatar
at first I thought it was an advertisement for harbor freight. I think I'll pass on putting the MERCON®SP fluid in my trans.
Old Jan 19, 2012 | 04:56 AM
  #32
joycesjag's Avatar
Its NOT 7.5L, its 7.5 US Quarts!
The kit from www.thectsc.com comes with 6 liters, that is all you need for a pan drop and fill. If you were to let set over night you would need to order a liter or 2 extra!
1 Liter = 1.05668821 Quarts [US] or
6 Liter = 6.34012926 Quarts [US]
Old Jan 19, 2012 | 10:38 AM
  #33
03Xtype's Avatar
No need for extra fluid, 6L is good enough. I'm assuming you had the car lifted incorrectly which caused extra fluid to drain from the converter and ect.
Old Jan 19, 2012 | 10:59 AM
  #34
joycesjag's Avatar
03, I don't think you get what I am saying........
Trust me the first vehicle, Joyces Jag was done on a lift perfectly level. I choose to use Castrol Multi Import ATF that came in US QUARTS, I let drain over night and filled with approx. 7.5 US QUARTS in the morning, 12 hour drain time. I rechecked the level 1 week later on the same lift and the level was correct and still is.
2nd vehicle, Joels 2003 S Type, I did in my garage and again the vehicle was perfectly level. I used the kit from thectsc which came with 6 LITERS and pan/filter. I let drain, oh about 10 minutes while I replaced the electrical sleeve, installed new pan/filter and added just shy of 6 LITERS back in to proper level. Joel had it checked about a week later at a transmission shop where he lives (3 hours away from myself) and the level was correct and still is.
Old Jan 20, 2012 | 05:03 AM
  #35
JagV8's Avatar
So it's something like air gradually getting into the torque convertor or the lines up to the oil cooler and the extra fluid gradually draining out, but only if you leave it draining overnight?
Old Jan 20, 2012 | 05:23 AM
  #36
joycesjag's Avatar
Apparently so.
Old Feb 3, 2012 | 03:50 AM
  #37
Teck4Jag's Avatar
The factory fills the gear box at 40c and i have seen some issues regarding shift quality even on newer xf/xk/xj, filling the gear box at exactly 30c yo can add up to 500-800ml of fluid, this temp is being monitored with the factory SDD tool. I have found the infrared tool to be not as accurate, but can get you by
Old Jun 19, 2012 | 12:46 AM
  #38
dsetter's Avatar
So, I have drained and dropped the pan to do a 110k mile service. The old oil was dark and the new oil is obviously clear and honey colored. The pan had just a slight amount of material on the magnets so I hope not a great amount of wear after the 110k miles.
Pan had the T30 larger size torx bolts and the date code on the pan said 2004 so I guess it might be the original "sealed for life" material. No leaks or other issues getting bolts out.
I drained 5+liters of oil out and got 5+ liters back in at ~40C.
The question though I have is what is 'level'.
The door sill?
The base of the transmission pan? (this is angled quite a bit)
The sealing edge of the pan (measuring with a level on the head of the pan bolts)
I am sure the angle of the car would have as much effect as the temperature.
I leveled the mounting level of the pan measured in the pan bolt heads.
This has the front low compared to the base of pan level and font high compared to the door sill.
I think it better to measure level based on the transmission as the suspension could give some different value of level if using the door sill.
I thought I should have got 5.5 to 6L back in, but was closer to 5.2L.
So, what should be level where when letting the fluid out.
Old Jun 19, 2012 | 07:07 AM
  #39
Jon89's Avatar
That is an excellent question. I believe most of us assume "level" is based upon getting the car in the air using jack stands that show four equal measurements of the distance between the concrete floor and where the top of each jack stand contacts the metal support piece of the underside of the car. If you're using a hydraulic lift at a shop, you're at the mercy of the lift apparatus being level since I doubt if there would be any "tilt" controls that you could manipulate - that would be dangerous and would add a significant degree of liability to the entire process....
Old Jun 19, 2012 | 07:52 AM
  #40
JagV8's Avatar
I find it hard to believe that the fairly small angular difference can matter since the box has to work at far bigger angles. Bear in mind, too, that its fill amount must have a max and min even if we don't know what they are.
