ZF6 Speed Transmission Message, STR
Old May 6, 2009 | 12:39 AM
jya's Avatar
jya
Question ZF6 Speed Transmission Message, STR
I am getting a message reading 'Transmission Fault' appearing on the dash where the odometer is, as well as a red vertical light appearing next to it on the left.
Dealers have run a diagnostic and they tell me that it is to do with the valvebody/overdrive solenoid that may be sticking. I find this odd as the car has only done 45,000KM! or(28,000Miles).
It only seems to appear at freeway speeds.
I have plenty of questions for the experts out there.
Is there a risk to keep driving the car?
Is this fault rare/common?
Certainly it would not be worth doing a full overhaul on such low mileage and I would hate to see the bill.
Is it worth/economical to repair this section of box only? Or should I just shop around for a used/exchange box?
I hear the fluid alone for the box is over $100 per litre! Times 8 or 9 litres!
Or should I just ignore it and it will magically go away!
Old May 11, 2009 | 08:22 PM
Kit1's Avatar
Mine has been doing this for over a year but it goes away itself after a while. I find that switching to Sport mode for a while clears the message.
Old May 12, 2009 | 01:15 PM
BHD2786's Avatar
If you could find out waht code was stored in the TCM that would help
clubairth1
30
Sep 3, 2025 04:38 PM
mrplow58
Jan 21, 2024 05:53 AM
Jandreu
Jun 30, 2022 03:10 PM
Dimitrigregorio
17
Sep 5, 2019 03:47 AM
PMKimpton
Aug 3, 2019 08:22 PM
