Shifter mount
Old Jun 7, 2016 | 07:44 AM
NathanDD6's Avatar
Default Shifter mount
Hi all
Here's a problem I've had since I got the car, the shifter sits high at the back, and it seems pretty firmly secured, I believe it bolts directly to the body, any ideas what could be wrong here?
Old Jun 7, 2016 | 08:07 AM
Never seen that before, but not real fiddly under that plastic cover.
Maybe the parts drawing will give you some hints.
Old Jun 7, 2016 | 08:13 AM
NathanDD6's Avatar
Item #6 and the plate above it maybe, or something up with item #17 and #23... I'll probe around soon. Thanks Grant!
Old Jun 7, 2016 | 09:34 AM
Maybe.
17 is pop rivetted to 22 & 23 and those rivets may be missing.
Old Jun 7, 2016 | 10:23 AM
JagCad's Avatar
Nathan:
I took mine apart. Swapped in a different tower and a new cable.
Fiddly, but, quite doable.
Seems like it is a cover in your car that is "proud", rather than the
shift tower. Proud is a wood worker's term !
So, it's a cosmetic thing, not a functional issue.
I've removed the "ski slope" in my car more than once
in fixing window switch issues as well.
Carl
Old Jun 7, 2016 | 03:31 PM
NathanDD6's Avatar
Thanks Grant, I'll have a look see when I'm next down there.
Been thinking that too Carl, could just be a dud cover, can it be removed by any chance? The PO has had his fingers in here though, so I'll maybe strip it all down and put it back, never know what I might find...
Old Jun 7, 2016 | 06:08 PM
Nathan, your selector cover is broken.
As Grant says it should be riveted as seen below:
The whole mounting flange seems to be missing from your shifter. It looks like it's broken off at that first bend. That's not surprising as it's decades old plastic.
One thing for sure, you'll need to remove the panel to do anything about it.
Old Jun 7, 2016 | 11:40 PM
Most common reason for that is that the "Cruise" switch needed access, and that is British Engineering at its prime.
There is a plastic slide type retainer under there, and unless that cover is raised at an obscene angle access is zero.
Once you have done it once it becomes simple, knowledge is golden.
The first time I wanted into there on the XJ-S it took me hours, and lots of funny words, and alcohol, before I relented and drilled out those rivets, and then all of 10 seconds to complete what I forgot I needed to go in there for.
Jags, got to luv em.
Old Jun 8, 2016 | 06:56 AM
NathanDD6's Avatar
Ah, all is making sense now, the PO has been in there, so he probably trimmed it... Many thanks, I can now reat at ease, I'll see to it when I can.
Old Yesterday | 08:32 AM
erjent's Avatar
Hi All,
The J-Gate on my 2000 convertible never worked at all. I opened the shifter uo to find one or two small broken plastic pieces.
I know I cant just get the disc, but may someone have one they don't want or need? Very willing to pay for it.
I couldn't find any info on possibly having one 3D printed.
Much thanks,
erjent
Punta Gorda, Fl
Old Yesterday | 04:51 PM
Ken Cantor's Avatar
Originally Posted by erjent
Hi All,
Much thanks,
erjent
Punta Gorda, Fl
I think you need this forum for the best advice on your car;
https://www.jaguarforums.com/forum/xk8-xkr-x100-17/
although you might find some in the X308 forum as they share some of the mechanicals with your car.
Good luck!
Old Yesterday | 09:12 PM
erjent's Avatar
Ken,
Thank you, I thought I was in the XK8 room.
kenneyk843
Nov 12, 2021 07:50 AM
garytalda
Apr 27, 2016 02:37 AM
Kief
Apr 26, 2016 10:29 AM
Dogbreath!
Apr 17, 2016 07:38 PM
ETexJag
Mar 30, 2016 03:34 PM
