2000 XK8 Coupe, Good Car???
Spend some time reading the sticky threads at the top of the XK8 forum. That will get you decently informed in a relatively short timeframe....
Can you obtain the maintenance records for the car you are interested in? They are essential....
If you cannot DIY your own maintenance and repairs, walk away regardless of how good the acquisition deal is. The car will chew through your bank account if you must pay someone else to maintain it for you....
This is some good reading about the engine: V8 Chain Tensioners Problems - Jaguar Clubs of North America
While the 2000 model is very nice, the 2001 model has the nice chrome boot plinth and chrome trim around the tail lights..where the 2000 model doesn't.
Had a 95' VDP and loved the car. Ran it to 165K miles and did nothing more that typical maintenance. The Chain Tensioner issue scares me. If it was done does that mean the bad parts have been replaced with redesigned (good) parts or just replacement originals? Is this more than a handy man can do in his driveway? Car has only 68K miles.
Mileage really isn't relevant on these cars. Age is the issue as all the rubber bits are likely in need of replacement. Hoses, and front suppension are the biggest issues. Yes anyone with basic knowledge and shop tools can do all maintenance in your driveway, I do and have actually enjoyed working on my 03.
This forum will be your life saver not to mention your wallet. As noted if you can't do your own repairs walk away.
Electronic issues are the most PIA problems and these cars are complicated beasts, but again with the help of the forum and some patience everything is doable.
According to what I have found on the internet the timing tensioner job can cost between $1200-$1600. I believe I could do the job myself but some special tool is required to prevent the cam timing from getting all out of sorts when the chain is removed. Anyone else have some numbers to go by? Do these cars typically have electrical issues? Any other expensive issues with these cars like transmission problems?
If you join the Jaguar Club of North America you can borrow all the special tools. They are kept at Coventry West in Lithonia. The North Georgia Jaguar Club is affiliated with the JCNA and is also a great social group that meets up in your area for drives several times a year. They are hosting the International Festival in October.
Many of us have replaced the secondary tensioners with the zip tie method that you will find on the forum. This is the most critical upgrade and it only takes a few hours. The rest of the job, chains and primaries, can be be put off until you have more experience working on the car, but not indefinitely.
I did the timing chain tensions on my 2001 XJ8 VDP. It had the same 4.0. I did the secondary timing chain tensioners only, and replaced them with the 3rd generation metal-bodies ones. This was using the "zip-tie method" which is well documented in the archives. Some will say to do the primary chain guides at the same time, and that is quite a bit more effort and requires special tools. But do some looking. It's definitely a job to get out of the way, if it hasn't been done.
Other thing to look for is tranny issues. Most seem to die around 100k with a broken drum, the updated fx from zf seems to be better. Personally I would rather get a car without the tranny being rebuilt by an unknown shop then having it done myself (I would pay less accordingly for a car that hasn't had it done). Aside from that it is as reliable as just about anything out there. Not a great car for someone who doesn't like tinkering just as any high dollar older euro car but if you're handy they are pretty easy to work on, just more complex then say a Toyota Camary but no more difficult.
You should probably get a pre purchase inspection since you're not familiar with the XK8. I have had some experience with Enzo's in Marietta and can recommend them if the car is in the Atlanta area. By the way , is this a red metallic car advertised on craig's list?
Enzo's Automotive Service ? Atlanta Jaguar, Land Rover, Ferrari, & Maserati Repair and Service
There are three different types of automatic transmission in these cars:-
4.0 XK8 non-supercharged ZF 5 speed - ZF 5HP24
4.0 XKR Supercharged Mercedes 5 speed - W5A580
4.2 XK8/R ZF 6 speed - ZF 6HP26
There is plenty of information on the forum as to the problems you get - the "how to" sticky at the top of this forum is essential reading:-
https://www.jaguarforums.com/forum/x...ts-data-29800/
So many good points have been brought up by our fellow members, I had read somewhere in these forums that cars like these need "caretakers". That, I agree with, there are common problems and idiosyncrasies that can crop up at any time, but previous ownership's care should show in the overall condition.
Yes, having mechanical aptitude and the ability to "DIY" is a big plus, but nontheless, these are some of the most incredibly satisfying and pleasurable, (and aggravating and frustrating) cars to own and drive, but it's just these things that make them more than "just a car!"
Do your due diligence, purchase intelligently, and you'll be rewarded with an Iconic car you'll be proud to own, as are we on these forums. Best of luck!
BK
BK
Received this note from the current owner. He has been very forth coming with information. Going to find out if he has receipts for the work.
Hi Ed - happy to answer any questions. The timing chain tensioners were replaced by the previous owner; I had the car inspected before I bought it and also ran a carfax report and they both came out perfectly clean. There's zero issues with the car, cosmetically or mechanically.
Received 2,406 Likes
On a car going on 20 years old? Yeah, OK.
I used this as a test when I was talking to the seller for what became my car. I asked him to go around the car and tell me EVERY detail wrong with it. As the seller played along and started listing every chip, crack and discoloration, I knew he was being honest with me.
I was looking at another car earlier. I did the same "trick" and the seller quickly gave me the line about "nothing wrong". Someone else ended buying that same car and a few days later posted on this list following a major cooling system failure. Just an anecdote, I suppose.
Great tactic fmertz. I will use it!
The owner just emailed me back and told me that the original owner replaced all of the tensioners and guides with the newer designed metal ones. Said he was a mechanic that had his own shop and did the work himself. He does have receipts for everything that he has done to the car since he has owned it but not from the original owner. Makes me nervous but the car is in such perfect shape and cosmetically maintained that it would be hard to believe that mechanically things were not taken care of?
Question? Is there anyway to tell if all the tensioners were replaced without a complete tear down? Can it be accessed with a bore scope?
Received 6,341 Likes
