Scanner says that my voltage is always 0
Fuse # 14 / 10 amp right engine bay fuse box for the sensors to be heated up ( heating element inside which is an easy check for that ) for them to operate properly
The input is 5 volts and the output is around 3.5 off the top of my head
The O2 sensors on the X300 are Titania based and not the more common
The scanner may not be able to read them and is looking for the more common type
To know that your O2 sensors are regulating the engine as the final competed outcome the Short Term Fuel Trim should be close to target value 0 % in all RPM / Load regimes
The dynamic moving graph is hard to discern but goes like this
If the sensors see an access amount of unconsumed O2 the computer will enrichen the mixture
More common you will have too little O2 as the mixture is too rich ( negative STFT number )
The range limit of the reader is + or - 25.4 % so that value is seen often as the regulation is not honed in to effecient
Don B (04-10-2024)
Received 12,769 Likes
Please tell us the rest of the story. What are the symptoms that prompted you to check O2S signals? Is the Check Engine Light illuminated? Are any Diagnostic Trouble Codes stored?
The X300 On-Board Diagnostics system is very early and primitive, and in my experience it cannot always be relied upon to give correct data.
Don
The following 4 users liked this post by Don B:
Have you done any work on the car during which the O2S electrical connectors might have been switched?
Is it possible that a rodent has chewed the O2S wires?
It is uncommon for two oxygen sensors to fail simultaneously...
P.S. In what thread did you make your previous post? I can move it here so all the pertinent information is together.
Don
Your a little bit low for a 4 .0 liter for highway speed , Question on the instrument cluster computed accuacy
Open / Closed ( efficient ) loop trigger is 88 C of the engine coolant temp senor
Cheap part but can be calibrated against page 78 as your meter will power the thermistor to function to give you a reading
At cool coolant at 86 F / 30 C you should see 1700 ohms
A higher resistance reading would be bad as a colder coolant temp reading ( thermistor reads opposite an old school thermocouple )
jagrepair.com/images/Training Guides/801S - 2000.pdf
Before and after installing Andy Stoddart's (XJRengineer) 5-degree timing advance bracket on my '93 XJ40, I conducted significant "scientific" fuel economy tests by repeated drives around a 60.0-mile circuit with only 5 stop signs. I would fill up the tank at Shell just prior to embarkation, then fill up at the same pump immediately upon return from the 60.0 mile circuit. I found that the on-board computer was consistently between 1.5 and 2 mpg off from actual fuel use, but it could be either high or low.
P.S. With Andy's bracket, actual fuel economy improved by almost 2 mpg, and mid- to upper-rpm performance improved also. I highly recommend his bracket to owners of late AJ6 and all AJ16 engines.
Don
The following 5 users liked this post by Don B:
944play (04-11-2024),
jomo (04-18-2024),
MountainMan (04-16-2024),
Parker 7 (04-11-2024),
XJRay (04-16-2024)
Hi,
I pulled out the easy two O2 sensors and will be checking them later. I assure you that I know just how to reconnect them--that is, I will not wire them backwards. My question is where are the connectors for those rear O2 sensors? A picture and some instructions will be helpful!.
Thanks for your time!
Jomo
Jomo
