LF - Wheel Bearing 2013 XF AWD
Old Apr 7, 2025 | 04:55 PM
RobertShaw's Avatar
Default LF - Wheel Bearing 2013 XF AWD
Hi all,
Apparently, my 2013 XF AWD 3.0 needs a new LF wheel bearing for which the dealer is quoting $1400 in parts alone because Jag has consolidated parts to include the vertical member (still not worth $1400).
Does the bearing or wheel hub have a separate part number?
Thank you!!
Old Apr 7, 2025 | 07:20 PM
POD XF's Avatar
In my experience, anything with a bearing in it can be dismantled and the bearing replaced; it puzzles me why car manufacturers some years ago went to throwing out entire assemblies rather than replacing worn bearings. The dealer is probably not interested, perhaps not equipped, to do this, but any decent independent workshop should be able to. Once it is dismantled, a bearing supplier would be able to measure, identify and source the bearing. One has to have very deep pockets to go the dealer path.
Old Apr 11, 2025 | 07:15 PM
xalty's Avatar
wheel hub on the awd is not bolt on. you're slide hammering the hub out, air hammering the old inner race out and pressing the new cartridge bearing in. the aftermarket bearings for an AWD XJ will be the same
https://www.jaguarforums.com/forum/x...xf-awd-195386/
Old Yesterday | 10:27 AM
JaguarXJL15's Avatar
please delete post
kkurulak
Jan 20, 2025 11:12 AM
Austin Laugen
Jun 28, 2022 11:38 PM
Howard2015XF
Nov 12, 2021 01:18 PM
ZK686
Jun 10, 2021 01:11 PM
hoylegj
Jul 18, 2018 06:01 PM
