Can I remove this trim piece without removing the dash?
Old Apr 2, 2026 | 08:26 PM
TraxtarXKR's Avatar
Default Can I remove this trim piece without removing the dash?
Does anyone know if this trim piece can be removed without uninstalling the entire dash?
I've got a rattle from this piece due to a broken tab, and I'm trying to replace it. Really hoping I don't have to pull the dash to access it.
Anyone have experience with this?
Also, if anyone has access to a salvage car and can sell me one in charcoal, I'll owe you big-time. It's no longer produced, and most salvage yards throw this away since nobody is crazy enough to replace it.
Old Apr 2, 2026 | 08:40 PM
Cee Jay's Avatar
3D printable?
Old Apr 2, 2026 | 08:52 PM
TraxtarXKR's Avatar
Not without the CAD file
Old Apr 3, 2026 | 12:07 AM
kj07xk's Avatar
Trying to visualize where that is. Under the steering column?
Old Apr 3, 2026 | 01:32 AM
LJRXKR's Avatar
It wraps around behind the centre console and neatly covers the spaces between the carpet and side of the glove box. Mine was really stuck when I was removing the glove box and broke it on one side. Found out it’s bolted in and you need to take apart a lot of the fascia. So it’s on my eventual to-do list.
PS I’m pretty sure it fits in top of the dashboard rather than behind the dash.
Old Apr 3, 2026 | 08:18 AM
TraxtarXKR's Avatar
LJRXKR is correct. It's a beauty panel that hides openings on both sides of the dash console.
It sits behind the infotainment system, and also behind the dash. It almost seems like it needs to be mounted while the dash is out of the car, but I'm hoping not.
I've been reaching out to salvage yards on eBay without luck. They all throw this piece away because it's a piece nobody buys.
Old Apr 3, 2026 | 09:41 AM
David993S's Avatar
Once you remove it, can't you just replace/fix the broken tab?
Old Apr 3, 2026 | 09:46 AM
TraxtarXKR's Avatar
Well it's plastic that's disintegrated into tiny pieces, so no.
Old Apr 3, 2026 | 10:09 AM
Cee Jay's Avatar
Scan existing pieces for printing in 3D
Old Apr 3, 2026 | 10:13 AM
TraxtarXKR's Avatar
I'm familiar with the process and have Solidworks and a printer that can handle ASA, but good part to scan and import. I have a broken piece, missing pieces, and the rest is stuck inside the car behind the dash. I can't have the car down for that much time... I need a good part to reinstall immediately after removing the bad one.
If someone has this part and a scanner and is willing to scan it and send the file, I can print it.
Old Apr 8, 2026 | 07:44 AM
pcoyote's Avatar
You can find this part on eBay as "10-15 Jaguar XK XKR 2014 Dash Dashboard Instrument Trim Cover Panel Bracket". It seems to be the same part for all model years. I replaced my dash and I didn't realize this part was broken on the passenger side. I think it goes behind the dash. I bought a part off of eBay and now I have to see if I can cut the part and get it in without lifting the dash or not. I will have to take the glove box out again to get to it, so I haven't attempted it yet.
Old Apr 8, 2026 | 06:33 PM
TraxtarXKR's Avatar
That did turn up some links, but unfortunately all the parts for sale are broken in some way.
Old Apr 8, 2026 | 08:56 PM
RoverJoe's Avatar
Community Influencer
Topix shows it coming out as one piece with the dash. The actual dash removal doesn't look too bad, once the console is out. That's still a bear of a job for a broken tab though.
File Type: pdf
Old Today | 03:51 PM
TraxtarXKR's Avatar
I think I've messaged 25 different Jaguar dismantlers on eBay, without luck. Jagbits and Welsh is also a dead end.
Part number is C2C28397LEG (Center Molding. Instrument Panel Molding - Black)
If anyone has access to a parts car with this piece, I'd love to know about it.
paXKid
Jul 31, 2019 02:50 PM
RonnieJoe
Aug 12, 2015 10:08 AM
RonnieJoe
Aug 11, 2015 04:42 PM
mep
20
May 1, 2015 11:29 PM
e21pilot
May 18, 2010 10:47 AM
