XF Sportbrake 2.2d Fuel Gauge Issues
Hello all,
I have XF Sportbrake 2.2d which is showing empty fuel gauge, even though there is fuel in the tank, and it starts and drives perfectly. I've put a new fuel pump in and it is still showing empty on the fuel gauge in the instrument cluster. I've also got the following fault codes, does anyone have any advice or guidance thank you,
IPC - Instrument cluster control module---(2)
2.1 B1A75-86 Fuel sender 1 circuit Permanent
2.2 B1A76-86 Fuel sender 2 circuit Permanent
BCMB - Auxiliary junction box (body control module B)---(6)
7.1 P0460-15 Fuel level sensor A circuit. Permanent7.4 P1346-15 Fuel level sensor B circuit Permanent
Thank you
Thank you
