XF 2.2D fuel sender
Old Jun 26, 2021 | 06:36 AM
Innes_UK's Avatar
Default XF 2.2D fuel sender
Hi this is my first post. I had an issue that sometime the fuel gauge would say I was out of fuel when I had plenty in the tank. 10 minutes later it would go back to the correct fuel level. I found the Jaguar fix on this forum
https://www.jaguarforums.com/forum/a...-operation.pdf
I have done to repair but now it constantly says it has no fuel. I waited a few days to see if it would sort itself out but no luck. I took the pump and sender out today to check the wiring connections and they look okay and secure but plan B is to solder the connections rather than crimp them. If this doesn’t fix the issue then I will try buying a whole new unit.
has anyone else tried this fix and had issues afterwards? How did you do. It? Also where do you recommend online I get a new pump/sender?
thanks!
Old Jun 26, 2021 | 06:45 AM
Nigwel1058's Avatar
thanks!
Check that the earth is ok on the sender or wiring.
no earth would give you a empty tank reading.
Aldo check you still have a live feed to the sender.
Reead Boodhoo
Apr 21, 2020 10:08 AM
FT1974
May 27, 2017 03:02 AM
jfintexas
Aug 23, 2013 02:04 PM
beanokim16
19
Nov 17, 2012 08:33 AM
Grant Francis
Jul 7, 2010 06:38 PM
