Fuel Gauge
Old Sep 26, 2018 | 09:32 AM
Vee's Avatar
Vee
Default Fuel Gauge
My fuel gauge is wrong. When full, it only shows about 3/4 tank. The red/low fuel light comes on when I burn through about 14 gallons of fuel.
I replaced the fuel float sensor in the fuel tank. The old one was doing the same exact thing as the new one I replaced it with.
When I shorted the two pins at the anti-slosh relay, nothing got any better.
Any advice?
Old Sep 26, 2018 | 09:46 AM
Greg in France's Avatar
The Great Palm is very good on how to clean the instrument electrical pathway. In my case the gauge read too low, and in the end I took the binnacle off and did all the things palm suggested. It cleared the fault. basically the current to the instrument is very low, and any, absolutely any slight, almost invisible corrosion or other slight insulant will give this problem. The current has to pass from the blue flexible track to a tiny self tapper then to a copper contact and there are loads of places even a small reduction in the conductivity will affect the gauge.
Old Sep 26, 2018 | 11:20 AM
Jagboi64's Avatar
When I pulled the sender out of a series III sedan the float was partially full of fuel. It's possible that everything is fine electrically, but not mechanically. You may have a partially sunk float.
EDit: nevermind, I just saw you replaced the sender.
Old Sep 26, 2018 | 02:13 PM
sidescrollin's Avatar
Sender is a fast check because it should vary between 20-220 ohms from one end of the range to the other.
It seems like you are generally having gauge issues. I've seen it recommended a few times to add an extra ground to the cluster in addition to usual cleaning.
BlackJack
Apr 7, 2018 07:57 AM
Zulu4me
Oct 3, 2017 06:55 AM
asleach2889
Mar 13, 2016 09:07 PM
amcdonal86
Jan 19, 2012 10:00 PM
Grant Francis
Jul 7, 2010 06:38 PM
