XF Sportbrake 2.2d Fuel Gauge Issues
Old Apr 27, 2026 | 05:53 PM
72773719's Avatar
Default XF Sportbrake 2.2d Fuel Gauge Issues
Hello all,
I have XF Sportbrake 2.2d which is showing empty fuel gauge, even though there is fuel in the tank, and it starts and drives perfectly. I've put a new fuel pump in and it is still showing empty on the fuel gauge in the instrument cluster. I've also got the following fault codes, does anyone have any advice or guidance thank you,
IPC - Instrument cluster control module---(2)
2.1 B1A75-86 Fuel sender 1 circuit Permanent
2.2 B1A76-86 Fuel sender 2 circuit Permanent
BCMB - Auxiliary junction box (body control module B)---(6)
7.1 P0460-15 Fuel level sensor A circuit. Permanent7.4 P1346-15 Fuel level sensor B circuit Permanent
Thank you
Innes_UK
Jun 26, 2021 06:45 AM
malc4d
Jul 29, 2019 07:45 PM
Vee
Sep 26, 2018 02:13 PM
v1rok
Jan 29, 2017 07:47 PM
jfintexas
Aug 23, 2013 02:04 PM
