Steering wheel rub
Old Today | 08:54 AM
JustABeginner's Avatar
Default Steering wheel rub
There is a small diameter copper wire or post between the part of the steering wheel that rotates and the part that’s stationary. It makes a high pitched squeak when I turn the wheel. More of a slight annoyance than anything. Is it supposed to be there for some reason, e.g., electrical conductivity? It’s at the six o’clock position. I can move it with a small screwdriver. Just trying to avoid pulling the steering column apart on a 2004 XJR. Thanks.
Old Today | 10:10 AM
mhamilton's Avatar
No wires should be protruding from your steering wheel.
Not sure how that wire would make a high pitch squeak--could that be a separate issue? There's a well known power steering whine that Jag issued a TSB for, the noise originates in the rack due to a seal but sounds for all the world like it's in the steering column inside the car. The fix is an additive to the p/s fluid. I found that draining and refilling with Valvoline MaxLife Synthetic ATF also solves the noise issue.
EdiM
XJ40 ( XJ81 )
Feb 11, 2026 10:40 PM
ftypedreams
Nov 22, 2025 04:05 PM
richardsjags
Apr 7, 2025 01:15 AM
Wayne Lea
Jan 15, 2022 06:14 AM
Johnken
Jul 1, 2018 05:19 PM
