Steering wheel rub
Old May 8, 2026 | 08:54 AM
JustABeginner's Avatar
Default Steering wheel rub
There is a small diameter copper wire or post between the part of the steering wheel that rotates and the part that’s stationary. It makes a high pitched squeak when I turn the wheel. More of a slight annoyance than anything. Is it supposed to be there for some reason, e.g., electrical conductivity? It’s at the six o’clock position. I can move it with a small screwdriver. Just trying to avoid pulling the steering column apart on a 2004 XJR. Thanks.
Old May 8, 2026 | 10:10 AM
mhamilton's Avatar
No wires should be protruding from your steering wheel.
Not sure how that wire would make a high pitch squeak--could that be a separate issue? There's a well known power steering whine that Jag issued a TSB for, the noise originates in the rack due to a seal but sounds for all the world like it's in the steering column inside the car. The fix is an additive to the p/s fluid. I found that draining and refilling with Valvoline MaxLife Synthetic ATF also solves the noise issue.
Old May 10, 2026 | 02:28 PM
Thomas-S.'s Avatar
Could you post some pictures? I think that they could be helpful.
Thanks!
Best regards,
Thomas
Old May 11, 2026 | 08:43 AM
Default Photo
Here’s a very zoomed in photo of the area between the rotating and stationary parts of the steering wheel. Notice the copper colored pieces that look like the end of a wire or spring. Tha
Old May 11, 2026 | 09:18 AM
mhamilton's Avatar
I can't tell, but those are most likely the brushes for the heated steering wheel. They are not going to be your issue.
Without hearing it, I'm just making a guess, but I would bet the steering whine you hear is covered by this TSB: https://www.jaguarforums.com/forum/a...266d1294814672
The additive is a small bottle p/n C2S 48887 that you add to the reservoir. Not sure if the additive is still being sold by Jag. It does actually work, but like I mentioned, you can also drain and refill the p/s system with Valvoline MaxLife ATF and it should accomplish the same thing. I prefer the latter because the p/s system tends to run the fluid pretty hot and needs to be changed.
Old May 11, 2026 | 03:55 PM
Will do. Thanks
EdiM
XJ40 ( XJ81 )
Feb 11, 2026 10:40 PM
ftypedreams
Nov 22, 2025 04:05 PM
richardsjags
Apr 7, 2025 01:15 AM
Wayne Lea
Jan 15, 2022 06:14 AM
Johnken
Jul 1, 2018 05:19 PM
